Bored and armed with a camera
Discussion in 'Photography Beginners' Forum' started by inTempus, Nov 25, 2009.
  1. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    I was bored last night and couldn't sleep. So I decided to do my first "water drop" photo... although it's a bit more than a drop. It's a bit of a splash I suppose.
    [​IMG]
    I grabbed a glass from the kitchen and a bowl of ice cubes and headed to the studio. I used my Canon 1D Mark III (gets sold Saturday, so I'm looking for reasons to play with it) w/85mm lens and my 580EXII and 430EXII to do this shot. I dropped a Sto-Fen on both flashes. I put the 580 on a remote cord and sat it on a stool next to the camera which was on a tripod. I put the 430 to the left and behind the glass. Using the remote release I stood next to the glass and just out of frame then dropped the ice cubes in the water. I had to time things perfectly as I only got one shot as my flash recharge time doesn't allow for continuous mode firing.
    It was fun. Now that I have the technique down, I will change up the backgrounds, get some gel's going and see if I can't do something a little more artistic/creative.
  2. CWN
    CWN TPF Noob!
    Nov 18, 2009
    173
    Splash seems a bit out of focus to me? Maybe just the resolution displayed...
    Also, the splash getting cut off on top kind of bugs me as well as the tilt... if the tilt was due to the actual glass being tipped, that would be cool - but the illusion, not so much.
    All in all a nice looking photo, just nothing amazing about it.
  3. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    It's not intended to be amazing, it was just practice on learning how to capture the action.
    The blur of the drops at the top is the result of motion blur. The focus was set on the center of the glass (which is quite sharply in focus). The camera was set to f/10. The strobes were set to high-speed sync and the shutter was set to 1/1250 which apparently still wasn't fast enough to capture the fastest moving drops of water.
  4. CWN
    CWN TPF Noob!
    Nov 18, 2009
    173
    That's some fast moving water.
  5. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    :hail:I bow to thee master :thumbup:
  6. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    It could be a limit of the flash, the duration might be causing the blur. If we could get Derrel in here he could probably tell me if that's the case.
  7. itznfb
    itznfb TPF Noob!
    May 21, 2008
    1,167
    Pittsburgh, PA
    That shot probably would be more interesting if done with a slow shutter.
  8. SrBiscuit
    SrBiscuit TPF Noob!
    Apr 22, 2008
    2,721
    44
    NH
    see i like the tilt.
    well lit...well captured. :D
  9. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    I did try that, I started off with 1/250 and worked my way up. The blur was too heavy for my tastes. I was thinking more like the Coke ads where the Coke is shooting out of the bottle and the liquid is perfectly frozen in time.
    Do you find the little bit of motion blur in the shot above objectionable? Or do you think it looks good and could use a little more?
  10. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,506
    15,225
    USA
    Not sure why you were using high speed synch mode indoors, since high speed synch mode does not stop motion--it actually tends to blur fast motion because there is not one,single burst of flash, but a rapid,almost continuous series of individual,low-powered flash pulsations at 50 KHz.
    Of course, if you wanted to blur the splash a little bit, high speed synch mode was a good choice. Otherwise, at a small aperture like f/10 indoors, not much ambient light would have entered with the shutter set to 1/200 second, and the single, instantaneous flash would probably have been somewhere in the 1/3000 to 1/10,000 second duration time frame, I'm guessing.
  11. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    Thanks! I'll give it another whirl tonight or over the holiday. I assumed that the faster the shutter the better my chances of freezing motion. So I'm going to slow the shutter down again and get out of high-speed sync mode. After thinking about it I figured the blur was probably a result of the flash.
  12. CWN
    CWN TPF Noob!
    Nov 18, 2009
    173
    Wow, learn something new every day - I was going to mention motion blur but figured there's no way that water could move fast enough under those conditions.
    Interested in seeing a re-shoot.
