Bridge at dusk. Lake Geneva, WI C&C
Discussion in 'Landscape & Cityscape' started by darkpbstar, Jun 13, 2008.
  1. darkpbstar
    darkpbstar TPF Noob!
    May 13, 2008
    273
    ok I was having some problems brightening up these images, and I'm not shooting in RAW yet, which I know is better for Post processing, but I only have a 1G card right now. So here is my attempt with these. C&C please. There is a little glare, because my UV filter was smudged a little.
    [​IMG]
    [​IMG]
    [​IMG]
  2. tirediron
    Jul 8, 2005
    40,875
    12,415
    Victoria, BC
    C&C per req:
    1. The main issue here is one of composition. The handrail which goes from bottom right to mid left leads the eye right out of the picture, without ever seeing the rest of it. Always try and use linear elements to guide the eye toward the centre of the picture.
    2. Generally, the rule of thirds will improve composition. In this case having the main subject running across the middle of the image detracts from the image. I would suggest a recrop so that if is closer to the lower third.
    3. Better composition; in this case the bridge and walk take the eye into the photography, although ideally they shouldn't go much past the halw-way point.
    All pictures seem a little soft and under-exposed.
  3. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    #3 looks cool!
