Bronica ETR help
Discussion in 'Collector's Corner' started by nealjpage, Apr 24, 2007.
  1. nealjpage
    nealjpage multi format master in a film geek package
    Sep 16, 2005
    3,479
    Oregon
    My new-to-me Bronica ETR came today in the mail. Pretty much meets description, except that it seems broken. I just put a new battery in it and a fresh load of Velvia. Problem is that the shutter won't seem to cock. Film will advance but not stop--I rolled through an entire roll without the shutter cocking. Took the film out and put it back through to roll it back onto the orignal spool, but it jammed up half-way through. Any ideas would be greatly appreciated.
  2. nealjpage
    Sep 16, 2005
    3,479
    Oregon
    Well, so much for that roll of film...
  3. RVsForFun
    RVsForFun TPF Noob!
    Mar 20, 2007
    184
    ...can you return it? It doesn't meet the description if it didn't say it was broken and it's broken. Repair on that camera can be expensive (it has in-lens shutters).
  4. Zatodragon
    Zatodragon TPF Noob!
    Feb 21, 2007
    95
    Washington State
    I have the Bronica ETRS, i'm not sure how similar the two models are, but i'll see if any of my experiences can help. When i first got mine, i had to monkey with the multiple exposure switch some before my shutter started to engage. It should be a little lever above your film advance mechanism<sp>. Without film in the backing and the protective screen removed, i advanced it some in single exposure mode, then switched it to multiple exposure mode, advance some more, and then switched back to single mode again and then it started to fire correctly and haven't had a problem since. Hope that helps!
  5. Paul Ron
    Paul Ron TPF Noob!
    Oct 11, 2003
    498
    7
    NYC
