Bronica Etrs shutter problem
Discussion in 'Medium Format & Large Format' started by XitzpatX, Aug 26, 2013.
  1. XitzpatX
    XitzpatX TPF Noob!
    Aug 21, 2012
    45
    I bought a bronica etrs about a month ago. It had been working fine till a couple days ago that I noticed. Now the shutter speed wont physically change no matter what speed the dial is at. Since I had already ran a few rolls through it and even checked the shutter when I first got it. I thought the battery might of died and it was running on the mechanical 1/500th. But I bought a new battery for it and the shutter still doesn't work properly. It appears to be firing on a consistent shutter speed and the aperture does close properly. But there is a red light that appears on the bottom right of the viewfinder showing that the battery is making contact.I tried two methods to check if its a problem with the lens or body and they're both working properly. I had read online that its good to use a silver oxide battery but when my camera worked it used a lithium battery. I'd rather not send it out to get it a CLA since that'll cost more than a new lens or body. Has anybody had this problem and found a way to fix it?
  2. timor
    timor Been spending a lot of time on here!
    Feb 28, 2011
    5,868
    876
    Toronto ON
    Contacts inside the lens are worn-down. Get another, working lens or you might try to fix it yourself. Here is the manual
    http://www.buonaluce.com/Slens.pdf
    Good luck.
  3. cgw
    cgw No longer a newbie, moving up!
    Feb 27, 2013
    1,426
    287
    Toronto
    With the lens wide open, you're actually seeing no change in the leaf shutter's speed, right?
  4. XitzpatX
    XitzpatX TPF Noob!
    Aug 21, 2012
    45
    Yeah the speed looks the same and it does it when I have the aperture stopped down too
  5. cgw
    Feb 27, 2013
    1,426
    287
    Toronto
    Mentioned wide open only to facilitate watching the leaf shutter work--aperture has no effect on the lens's shutter. What's up with the film you shot? Battery type shouldn't be critical. Lens/body contacts clean? Do you have a metered or prism finder?
  6. XitzpatX
    XitzpatX TPF Noob!
    Aug 21, 2012
    45
    I shoot regular 120 film, the contacts look good and clean, and I use a prism finder
  7. cgw
    Feb 27, 2013
    1,426
    287
    Toronto
    But you said in your opening post that you'd shot several rolls with this camera. How'd those turn out? Have you shot anything "post-problem?"
  8. XitzpatX
    XitzpatX TPF Noob!
    Aug 21, 2012
    45
    Ohh yeah I had put about 4 rolls through it, as of exposure it looks accurate except for the last photo on the last roll. It was really underexposed, I had the camera set to 1/8th at the time which is what my light meter read so that's probably when it started messing up. Other than that one exposure I havent shot anything after it
  9. timor
    Feb 28, 2011
    5,868
    876
    Toronto ON
    Do you have always your metering prism on the body ? Which type is it ? Was it turned on when you were investigating the problem ?
  10. XitzpatX
    XitzpatX TPF Noob!
    Aug 21, 2012
    45
    Its not the metered prism I was just referring to my hand held meter sorry for the confusion
  11. timor
    Feb 28, 2011
    5,868
    876
    Toronto ON
    So, what kind of viewfinder do you have for this camera ?
  12. XitzpatX
    XitzpatX TPF Noob!
    Aug 21, 2012
    45
    I use the prism finder-e
bronica battery check not working and shutter not firing
bronica etrs home page
bronica etrs lens stuck
bronica etrs problems
bronica etrs shutter speed problem
bronica etrsi sticking shutter
bronica shutter problems
clean contacts bronica
etrs can a faulty ae finder stop shutter firing
etrs shutter will not fire
