Building my own power pack - Which Inverter?
Discussion in 'Beyond the Basics' started by kawasakiguy37, Jul 10, 2010.
  1. kawasakiguy37
    kawasakiguy37 TPF Noob!
    Feb 26, 2010
    42
    Im looking to built a powerpack to power some alien bee monolights. I know supposedly the Vagabond II somehow uses a samlez 150W (continous) inverter, even though even the weakest alien bee seems to peak at more than the samlex can output (300w surge).
    How is this possible? Ive looked at some other pure sine inverters like these:
    Pure Sine Wave Power Inverter 120 watt - DonRowe.com
    Pure Sine Wave Power Inverter 300 watt - DonRowe.com
    and finally this:
    2200 ? Elite 180W
    Are these units actually able to output higher surges than they are rated? Or am I missing osmething here.....FYI, alienbee spec sheet can be found here:
    AlienBees Specs Chart
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Peak and continuous power are different.
  3. kawasakiguy37
    Feb 26, 2010
    42
    Yes, what are you trying to say? There are peak power ratings for both the inverters and lights but I am confused as to how they match up. Do I simply need an inverter with a 360W peak rating to power a light that takes 360W?
  4. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Going to revisit this.
  5. wesd
    wesd TPF Noob!
    Feb 12, 2007
    246
    Manchester, NH
    Also remember to think about the efficiency of the inverter, if more than half the the juice is being converter to heat than your not going to get as much out of the batteries. Will your strobes run off DC?
    Wes
  6. kawasakiguy37
    Feb 26, 2010
    42
    No I believe they are AC only (usually plugged into wall).
    Those inverters state 85-90 percent efficiency, is that good? Sounds good....
