bulk resizing
Discussion in 'Photographic Discussions' started by Nigel A, May 16, 2007.
  1. Nigel A
    Nigel A TPF Noob!
    May 14, 2007
    8
    TAUNTON, UK
    I need a bulk resizing program where one can put in the maximum size allowed for the images.
    The issue at the moment is that the criteria for uploading to the hosting site is presicely 500pixels on the longest side and not more than 110kb. With the current program (IrfanView) it does the job well except that very often the images are as small as 35kb. Those in landscape format are often proportionately larger and the pixels on the longest side often have to be set as low as 350 or 400 to ensure that the images does not exceed the 110kb.
    Any comments or suggestions please will be very welcome
  2. mmphoto
    mmphoto TPF Noob!
    May 15, 2007
    82
    Chicago, IL
    I'm with you! i would LOVE to know how to bulk resize to specification!
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I use Irfanview or Photoshop. What I do, is to resize them in two batches...the vertical ones separate from the horizontal ones. Then you can set the longest side precisely.
  4. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Mike
    You can do them in one go in Photoshop. Set the maximum sixe horitontal and vertical the same. So say max size vertical is 800 pixels and horizontal is 800 pixels. It will kjeep the ratios the same.
    I do this in Image Prcessor and use the resize to fit..... It will keep all your images the right size :)
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Ofcourse lightroom does it as well, and works exactly the same way.
  6. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    In fact more recently it's lightroom I've been using for this. it's pretty quick too.
