jadin
The Mad Hatter
- Joined
- Feb 18, 2004
- Messages
- 1,753
- Reaction score
- 10
- Location
- Down the Rabbit Hole.
- Website
- jadinhanson.smugmug.com
Based on what you said, almost definately go digital with either nikon or canon. Simply because you will have the widest lens choices in the long run. Find a cheap body and get it (I'd recommend ebay or similar, since you don't need new if you aren't going to keep it). Spend the money you save on buying high-quality lenses. Then when you are comfortable enough to move on, you're all set with your lenses, and haven't spent a lot on your body so you won't lose too much when you go to resell it, and can afford to get the camera you will stick with for the long haul.
As far as learning goes, digital, digital, digital. I've shot maybe 10 rolls of film in my life, and I didn't learn a thing with them, save maybe how to use the light meter. With digital it records all your settings when you press the shutter right into the picture. You don't have to guess, or write anything down. Back on your computer you can see the data for each and every shot and can see where you went wrong quickly and easily. For a learning tool it's hard to beat. About the only exception to this would be if you had a darkroom at your beck and call.
