Buying a Saunders 670 DXL Dichroic Enlarger on eBay...
Discussion in 'The Darkroom' started by lawrenceismia, Sep 11, 2006.
  1. lawrenceismia
    lawrenceismia TPF Noob!
    Sep 10, 2006
    5
    According to the seller, it's only been used 2-3 times and it comes with:
    "2 Nikon El-Nikkor Lenses (1- 50mm / 1:2.8 and 1- 75mm / 1:4), Gralab Model 300 Timer, Beseler Enlarging Timer, 6 Saunders Negative Carriers (the 6x7cm and 6x6cm carriers are NEW and never used), Saunders 14x11 Easel, Bogen 8x10 Easel, Premier 4 in 1 Easel, Bestwell Grain Focusing Scope, and a Print File Custom Proofer (LK New and Never Used). All the accessories are in excellent shape and some have never been used."
    Price isn't really the issue here. The issue here is that Saunders went out of business at one point and I'm not sure if I should buy an enlarger where the parts (if replacing is needed) are not available. However, I'm thinking that since it's only been used 2-3 times and the photos provided of it seem to prove that, it should last me a long time without parts breaking down.
    Should I invest in buying this enlarger? What do you think it's lifespan could be?
    [​IMG]
    [​IMG]
    [​IMG]
  2. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    I can't speak for this particular enlarger, but I have a Chromega which is at least 25 years old and performs beautifully. It might set your mind at ease to check and see if the particular bulb used in the enlarger is available as a replacement.
  3. lawrenceismia
    Sep 10, 2006
    5
    Yes, that does help to set my mind at ease. :)
    For the bulb type the only description it gives of it is:
    Lamp- 100W 12V Quartz Halogen Lamp (EFP)
    Which I'm guessing is available as a general item.
saunders lpl 670 dxl
saunders 670 dxl
saunders dichroic
saunders lpl 670 dxl dichroic enlarger
