Evan55T
- Joined
- May 17, 2015
- Messages
- 61
- Reaction score
- 4
- Location
- NJ
- Website
- forumserver.twoplustwo.com
- Can others edit my Photos
- Photos OK to edit
My guess is that the shutter count is a 16 bit counter and it has rolled over. This means that your 3896 clicks is actually 64K(65536) + 3896 = 69432 clicks.I'm not sure how accurate those shutter counters are I have a d3s I taken over 60000 pictures on and when I check with 3 different online counters it comes up as 3896 clicks
or the shutter assembly was replaced.My guess is that the shutter count is a 16 bit counter and it has rolled over. This means that your 3896 clicks is actually 64K(65536) + 3896 = 69432 clicks.I'm not sure how accurate those shutter counters are I have a d3s I taken over 60000 pictures on and when I check with 3 different online counters it comes up as 3896 clicks
Okay help im not sure if this is the same situation with this used d700 i am buying it says the shutter count is 2333 and it says the image count is 2333 as well in post process softwares, but you mentioned the shutter count is a 16bit counter and the 3ds is similar to the d700 so the camera im buying is around the same shutter count?
I posted all the information in this thread here Buying used/refurbed photography gear w/no knowledge?
