the sunrise looks pretty good, the horizon is straight.
the bird is in great focus, i like the DOF, but maybe a tighter crop would work for this photo
ideally, i would have done HDR for the sunrise picture, but i haven't yet to learn that.... but eventually. I have nikon d40 so i would have to do the bracketing manually, o well
For the sunrise picture. Im not positive but im pretty sure that you might not be metering properly. See how its a little too dark on the rocks. So it seems that you metered the sky/sun which gave you a slower shutter speed which ended up darkening the rocks. One tip for that situation is to meter your hand since it is very close to middle gray or to carry around a gray card which would fill up your frame when metering to give you an accurate exposure. You can also purchase a light meter. Good work with the bird. Very well done.
That would be a graduated ND filter. It was made specifically for applications like what you encountered.
