Calculating exposure difference with ND Filter
Discussion in 'Beyond the Basics' started by benjyman345, Mar 7, 2007.
  1. benjyman345
    benjyman345 TPF Noob!
    Sep 26, 2006
    152
    hello,
    I was wondering, how do i calculate the difference between exposures when using a Neutral Density (ND) filter?
    I.E. 2x, 4x, 8x
    Thanks
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    there are different ways of labelling ND filters. I guess the numbers you gave just mean you multiply by 2, 4, 8, ...
  3. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
  4. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    If you are using a modern camera (with a built-in meter) then once you put the filter onto the lens, the meter readings will be compensating for the filter.
    You do have to calculate it manually when you are using a hand held meter.
  5. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Well, if you use a 64x filter in dim light (to get ultra-long exposure), then the sensitivity of the built-in meter is usually not sufficent to give really accurate values (all you see is black ;) ).
.09 nd filter
calculate exposure for nd lens
calculating exposure with nd filters
exposure calculator nd filter
how much difference between an 8 and a 10 nd filter
how to calculate nd filter
how to calculate nd filter exposure
how to calculate neutral density filter
long exposure conversion with nd filters
nd filter calculation
