Calibration
Discussion in 'Beyond the Basics' started by Josh66, Jul 30, 2009.
  1. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    OK, I know that you need to calibrate your monitor, and I do.
    But, there are a lot of choices out there.
    Right now I use the Huey, by Pantone.
    What will a "better" unit do for me that the Huey can't?
    So far, I think it works pretty good. Have any of you noticed my colors being 'off'?
    I guess I'm just wondering if it's worth upgrading. What kind of difference will I see, or what new abilities will I get that I don't currently have?
  2. Andrew Boyd
    Andrew Boyd TPF Noob!
    Jun 9, 2009
    81
    New Orleans, Louisiana
    I upgraded a couple of years back from the Spyder probe to the Eye1Display2 monitor probe. This is the bomb! It calibrates in regular daylight (no need to shield your monitor from ambient light) and does a great job of setting your overall color and luminance points. You can also create a monitor calibration and then use it to set calibration on other monitors too.
    If you haven't considered it, go to Eye1color and check it out.
    Andrew Boyd
    TheDiscerningPhotographer
  3. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    The Huey Pro calibrates for different ambient light... it's done that for a while. Plus, if you leave it plugged in and in the cradle, you can set it to constantly update your settings based upon the ambient light.
    I use the Huey Pro because I've used more expensive tools (at work) and honestly, I see no difference, certainly not a $200+ difference. The Huey is only $90.
    If you're printing photos and want to calibrate your printer to your monitor, then I would go with the ColorMunki. I'm actually going to pick one up when I finally jump on that Epson R2880.
  4. Mr. Murmeli
    Mr. Murmeli TPF Noob!
    Jan 10, 2009
    92
    Finland
    How well does the apparently very popular Spyders fare compared to other calibrators? I've seen some very cheap prices for the Spyder2 but will it adjust the colors good enough?
    My monitor is Lenovo L220x (S-PVA panel).
    Thanks!
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Here's the thing. Compare it to a good print. Do you get the colours you expect or is there a colour cast or a saturation change?
    I have an eyeOne Display2. NEC actively recommend NOT using a Spyder 2 on any wide gamut display. The only reason you would want to upgrade is if your current device is not providing the correct reference colours or if the current device doesn't support your screen.
    Everything else is just procedural. The huey calibrates for your room lighting conditions? Constantly update? Horrid. Completely bad form. You should calibrate your room light to the standard, then it doesn't matter anymore, a procedural issue rather than cutting corners. Then any working device that works on your display will do.
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    I use the EyeOne Dsplay 2 as well (I have dual monitors). It made a big difference for me once it was set up properly. If you go online and do the research, the Spyder is the one that is most often bought... and has the highest complaints by far too.
    I'd suggest the EyeOne first and Huey 2nd.
  7. DScience
    DScience No longer a newbie, moving up!
    Apr 12, 2009
    1,513
    122
    Denver, CO
    get a mac
  8. JerryPH
    Oct 14, 2007
    6,111
    15
    Not happening. They are going to have to pry that PC from my cold dead hands. :lmao:
    The Huey does a nice job, it is not going to do anything drastic for you to change calibrators. The fact that it is calibrated is the big difference... as long as you are calibrating the monitor properly.
  9. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    The 'regular' Huey does too. That's another thing I couldn't really see the difference on - regular Huey vs. HueyPro.
    Why?
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Maybe becuase he doesn't know that they need calibration too? :razz:
  11. Plankton
    Plankton TPF Noob!
    Feb 24, 2009
    145
    western Massachusetts
    I'm assuming he meant that they have a built in calibration tool. But, the discussion is about harware calibrators which are far superior to calibrating with your eyes. So mac or PC...doesnt make a difference.
  12. JerryPH
    Oct 14, 2007
    6,111
    15
    Oh my gosh yes, not even on the same planet. Adobe had a software calibrator built into CS2 and it did get you closer, but it was surprising how far off it still was after I did my first hardware cal.
    Just becuase you have a MAC doesn't mean perfectly calibrated monitors. MAC users should do the same things PC users do.
carl zeiss jena calibration geometric
