- Joined
- Dec 11, 2006
- Messages
- 18,743
- Reaction score
- 8,047
- Location
- Mid-Atlantic US
- Website
- www.lewlortonphoto.com
- Can others edit my Photos
- Photos NOT OK to edit
I have a small problem that I'd like to fix easily.
I download bulk metadata from Zenfolio in a cvs file in a slightly non-standard format.
The header row has no double quotes and the first column has no quotes.
I edit the file in a spreadsheet (in my case OpenOffice Calc) as suggested.
The output from Calc has quotes around the header row and ever text field output
I can clearly fix the header line with a paste but I'd like to be able to run this through a little application to fix everything easily without having to use a text editor (invariably I miss one or delete a comma I do need and it takes me forever to find the error)
What simple programming language would you suggest I can learn easily just to do this?
(I don't mind the learning, that would be fun compared to editing that metadata file with a text editor.)
TIA,
TIA,
