Camera and Flash Compatibility
Discussion in 'Beyond the Basics' started by marcuspeddle, Oct 11, 2008.
  1. marcuspeddle
    marcuspeddle TPF Noob!
    Sep 28, 2007
    54
    Gangneung, South Korea
    I have a Nikon SB-600 flash and it obviously works with Nikon cameras. I also have a Contax 645 medium format camera but I don't have a Contax flash. What's more, the Contax flashes are expensive and it wouldn't be worth buying one for the few times I need flash for medium format. How can I check to see if a flash and camera from different cameras are compatible? The SB-600 has no place for cables so it could only be used in the hot shoe.
  2. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    You can get an off brand flash for it, say a Vivitar 283 or 285, or a Sunpak 383. Probably others that have their own built in meter. You'll just have to set the sync speed on the camera yourself.
  3. Village Idiot
    Mar 20, 2008
    7,274
    406
    No you don't and sync speed is a product of the camera and not something you set.
    It has a sync terminal. You could put a piece of electrical tape on the hot shoe, put the flash on the hot shoe, then use a pc cable to go from the sync port on the camera to the sync port on the flash. You'd have to use it in full manual though.
    Anyways, photo with the sync port is on pg. 7. And x sync is 1/90.
    PDF - 9 megs
    http://global.kyocera.com/prdct/optical/support/manual/645_eng.pdf
