Camera bounce prevention?
Discussion in 'Beyond the Basics' started by Big, Aug 24, 2009.
  1. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Is there any way to keep the camera from bouncing and swaying around when hanging off my neck in front of me? (preferably something homemade) I tried moving it to the side so that the camera is just behind/under my armpit but it's not the quickest and easiest way to carry it if I need it in a split second due to big shoulders and long arms... It gets old having it swing around while on walks or hikes.
    Thanks!
    -BIG
  2. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
  3. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Thanks Ian, I think I'll look into the stabilizer strap, it looks worth it.
  4. msf
    msf TPF Noob!
    May 6, 2007
    314
    In the South
    when im hiking I normally have my backpack with me *few waters, maybe a lens or two, trailmix* and I have the same problem. With the battery grip the camera doesnt tend to aim down. I was thinking of perhaps getting a couple of those metalic clips *looks like a deformed D* and clip the camera strap to both shoulder straps. But that doesnt completly remove the strain on the neck unless you dont put it around your neck and just let it hang off of the clips. But then it might be to far down and occasionally hit you in the gut. :)
  5. KmH
    Apr 9, 2009
    40,738
    5,587
    Iowa
    www.blackrapid.com
    Camera straps are really designed to go over a shoulder not around your neck.
  6. Stranger
    Stranger TPF Noob!
    Jul 9, 2007
    495
    +1 I love this strap.
    Took a while to get used to it but i now completely trust it with my gripped Fuji S5 + SB-800 + Sigma 70-200 2.8
  7. loopy
    loopy Brave little froggy...
    Jan 12, 2005
    389
    34
    Southern Alberta , Canada
    Ducktape?
  8. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    KMH: Like I said, I have tried putting it around my neck with the camera under my arm on the side but if something comes up quick, there's just no way I can pull my arm through in time.
    Loopy: Well, I figured someone would tell me about something that's like $100...;) I am trying to save money. I really like that stabilizer strap though.
  9. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Also, not to be rude but who says cameras were designed to be worn on the shoulder, I just came back from the zoo today and I saw one person out of probably one hundred that had their cameras in front of them around their necks. (most were dslr) It may feel heavier but at least it won't accidentally slip off.
  10. loopy
    Jan 12, 2005
    389
    34
  11. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    That blackrapid thing reminds me of a type of strap the Leica folks have been using for years. The issue I have with that type of design is that it had a tendency to still swing around with body movement as well as slide forward once you bend forward. I once knocked my son in the head when I bent down to assist him a more difficult part of the trail we were on.... he was NOT happy.. (I fixed the issue with a modified lens pouch to serve as a holster.. not an option for a large SLR). Does the Blackrapid strap have some of solution for this?
    Website for the Y-strap: Y Strap « The Figital Revolution
    (I made my own with material I had in my shop).
  12. KmH
    Apr 9, 2009
    40,738
    5,587
    Iowa
    With the Black Rapid strap you don't take your arm out of the strap. The camera slides along the strap. If you watch their video it becomes much clearer how advantagous the strap can be. The Black Rapid strap is the quickest I have ever used.
    Not rude at all. Remember you are watching a large group of amateur photographers. If you look at how pros use a strap will will observe the exact inverse of your observations at the zoo.
