Camera for Sports
Discussion in 'Beyond the Basics' started by DrewR, Apr 3, 2006.
  1. DrewR
    DrewR TPF Noob!
    Apr 3, 2006
    6
    I just did a search of the forums and didn't manage to find an answer for my question.
    I am a very avid mountain biker and sportsman, But equally as enthused with Photography/Airbrushing and other forms of art...
    What i am in need of at the moment is a DSLR camera too shoot very high quality pictures....So i ask; What would be the best or very high quality camera/lenses to shoot with....If anyone knows of a place that sells the particular product for cheap please let me know as well....
    Price isn't TOO much of an issue...But i don't want to be spending crazy amounts.
    Any help would be appreciated,
    Drew.:wink:
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    I'd say a Canon Digital Rebel XT would be a good, cost effective option. It's a solid camera...shutter speeds up to 1/2500 of a second. I'm sure some of the Nikon heads or other digital fanatics will jump in with other advice.
  3. DepthAfield
    DepthAfield TPF Noob!
    Feb 24, 2006
    566
    Itchycoo Park
    Nearly any of the major brand camera DSLR bodies will suit your needs. More important however, is the quality and speed of lens attached to that body. If cost is unimportant, I would suggest buying a fast zoom with image stabilization… I can’t speak for the Canon equivalent, but the Nikkor 70-200mm F/2.8 VR is phenomenal and can be found online for about $1500 US.
    Please keep us posted on your decision!
  4. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    Canon Rebel XT is a good camera but i reckon you might be better going for the 20D. The XT is limited to 3fps where the 20D can shoot at 5fps. If you're keen on sports AND photography and combining them then the faster burst mode might be worth the extra cash.
  5. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Define crazy... To me, crazy money is more than $10,000 per item, but to you, it may be say $100 per item. Photography is a remarkable thing as you can spend staggeringly huge sums of money.
    As has been mentioned, if you want top-end stuff for sports and action, then you want to be looking at a mid to high end camera, like the Canon 5D or Nikon 200D with a pair of high-speed, wide-aperture-capable zooms which cover the 28-70 and 100-400 type ranges. Also, you'll probably want a prime at about 300mm. That little lot would set you back probably $5k - so, is that crazy??:confused:
    Rob
  6. DrewR
    DrewR TPF Noob!
    Apr 3, 2006
    6
    Well, 5k is border line- But anything beyond that i find 'Crazy'.
    Thanks for the input so far.:thumbup:
  7. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Ok,
    Here's a proposed shopping list for you then:
    Canon 5D body: $3,000
    http://www.bhphotovideo.com/bnh/con...s&Q=&sku=397314&is=REG&addedTroughType=search
    Wide to telephoto fixed aperture zoom: $1,100
    http://www.bhphotovideo.com/bnh/con...04&is=GREY&addedTroughType=categoryNavigation
    Decent zoom telephoto: $1,400
    http://www.bhphotovideo.com/bnh/con...616&is=USA&addedTroughType=categoryNavigation
    Large aperture prime: $6,400 (hmmm not quite in budget there!)
    http://www.bhphotovideo.com/bnh/con...52&is=GREY&addedTroughType=categoryNavigation
    In addition to that, you might want a standard lens at about $100.
    You'll also want a decent tripod, probably a Bogen / Manfrotto
    http://www.bhphotovideo.com/bnh/con...163&is=REG&addedTroughType=categoryNavigation
    And a mono pod
    http://www.bhphotovideo.com/bnh/con...520&is=REG&addedTroughType=categoryNavigation
    A decent flash setup:
    http://www.bhphotovideo.com/bnh/con...464&is=USA&addedTroughType=categoryNavigation
    A decent bag:
    http://www.bhphotovideo.com/bnh/con...100&is=REG&addedTroughType=categoryNavigation
    Ok, so I've gone a bit overboard on the accessories... but I was having fun doing virtual shopping.
    If you actually did go out and buy that lot, you'd have serious difficulty blaming the equipment if your shots don't come out well!
    Rob
  8. DrewR
    DrewR TPF Noob!
    Apr 3, 2006
    6
    Thanks for that Rob....Most of those accesories sound great...Just the body i am still not quite sure on....
    What would be the reasons you would get the Canon 5d body over the Canon 20d body? Because there is a very noticable price difference in the bodys and i'm just not sure if getting a 5d would be worth the extra $1500 over the 20d?
  9. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    The 5D has a "Full frame" i.e. 35mm equivilent sized sensor, which allows wider lenses to capture their full width. With an APS-C sized sensor (10D, 20D, 30D, 350D), you get the middle bit cut out - an effective crop of 1.6x smaller. Also, larger sensors are less prone to noise as they have larger light gathering ability.
    True the 20D is a bargain compared to the 5D, also there's the newer model the 30D. I'd say look at the fps rate if you're mainly doing sports. There will not be a huge difference in image quality, but there will certainly be a big difference in the field of view of your shots.
    Also, larger sensor = larger mirror and therefore brighter viewfinder and easier composition in both low light and action.
    Rob
  10. DrewR
    DrewR TPF Noob!
    Apr 3, 2006
    6
    Im pritty interested in this lense, However i also want a very wide angled lense (10mm) Do you have a reccomended wide angled lense?
  11. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    If you're after fast and wide, Nikon would be a good move as they produce the only digital fish eye lens. f2.8 10.5mm. iIt's around £300/$500.
    If you want something fast then the D2Hs shoots at a very fast 8fps though is fairly "old" in DSLR terms. I would expect a D3 series within the next 6 months from nikon.
    If I was in your position I'd get a D200 with a grip and a whole host of lenses. It's an absolute bargain when you compare it to the top end of the DSLR market and gives them a good run for their money.
  12. kemplefan
    kemplefan TPF Noob!
    Jan 24, 2006
    297
    Baltimore maryland
    i would say a D200 wiht vertical grip, 85m f 1.4 and a 70-200mm vr zoom
