Camera grip for 30D or 5D. Any use?
Discussion in 'Beyond the Basics' started by Frankieplus, May 4, 2006.
  1. Frankieplus
    Frankieplus TPF Noob!
    Apr 10, 2006
    23
    Any use in a camera grip for someone who's not really a pro photographer? What are the benefits of owning a grip?
    Does it protect the camera from wear and tear in any way cause your hands aren't on the camera body? What's your opinion on grips..
    Just wanting to know if owning a grip for the above camera is dumb unless you're a pro photographer.
    -Frankie
  2. Azuth
    Azuth TPF Noob!
    Dec 25, 2005
    262
    Sydney 'strailya
    The grip extends your battery life, and can make the camera easier to hold when it's essentially on its side. These can be good things.
    It also adds bulk and weight, which can be good or bad. Best advise would be go into a store and have a play with one with the grip attached.
  3. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Grips are great if you've got big hands and you like a weighty camera. They're particularly useful for longer lenses as it helps the front to back balance of weight. Some also add power allowing for longer battery life.
    They don't particularly protect the camera, although if you're going on and off a tripod a lot, it will cover that area. Basically it covers the bottom plate, so it depends on what you're doing.
    Rob
  4. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    I like having a battery grip on my camera because it gives me an extra shutter button for when I'm holding the camera vertically (so my right hand can be in a more comfortable position). On digital cameras you also get longer battery life. It's up to you if those things are worth the price.
