Camera Issue, Can anyone help?
Discussion in 'Digital Discussion & Q&A' started by anet0601, Jan 19, 2009.
  1. anet0601
    anet0601 TPF Noob!
    Jan 19, 2009
    I purchase a D90 in November, which I do love. However, a couple of days ago the pictures I have taken in two different basketball gyms have had problems. the exposure seems to look different on different areas of the photo. (Like from a pickish cast to a greenish cast) It seems to go from bottom to top or top to bottom, even a strip in the middle of the pictures. I have taken pictures in these gyms before and they were fine. The lens is the Nikon 70-200 2.8. I put the lens on a different Camera and the pictures were fine. WB was set to floresant. I stepped outside changed settings for outdoor and the pictures were fine again. Any ideas?
  2. tirediron
    Jul 8, 2005
    40,933
    12,434
    Victoria, BC
    Sounds like something might have become "stuck" in the software. Can you post a couple of examples?
  3. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    Sounds like a white balance issue....
    Next time ur at the gym put the camera on live view and use the K setting on white balance..... then scroll through the temperature until you have a reasonable match.. then turn off live view and shoot ...
    if ur shooting raw you can also adjust the temp slider in post processing
  4. tirediron
    Jul 8, 2005
    40,933
    12,434
    Victoria, BC
    That was what I thought until I got to the "Stripe down the middle" bit..
  5. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
    lol.... can you say selective reading??? I didn't even see that bit...
    OP - You gotta post a pic
  6. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    OK it sounds like data corruption to me at first. But it could be a bad sensor. First waht SD card are you using and, do you have a spare? I would try a second card and, see if you can repeat the error on that card first. Also try using close to the same lighting if possible.
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    What ISO? Colour accuracy goes out the window at really high ISO settings.
