Camera Shake ~ Shutter Speed = Focal Length?
Discussion in 'Photography Beginners' Forum' started by prodigy2k7, Jun 23, 2008.
  1. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    Ive heard that to counter camera shake without a tripod using shutter speed, you must have the same or faster speed than the focal length of the lens.
    Example: 75-300mm lens, zoomed to 300mm, you should use atleast 1/300 right?
    I heard that only works sometimes, so, how do you know the minimum speed you should use?
  2. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    That's a great rule of thumb. However, that's given in 35mm lengths, so with a crop sensor, multiply by 1.6. So, at 300mm on a crop camera, try for something near 1/480 second.
    IMO that's usually pretty conservative and you can get by with slower.
  3. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    Care to show me a reputable source that says that crop factor has to do with camera shake?
    Crop factor only has to do with field of view(and since crop factor is due to a less than x sized sensor, often 35mm, there are also issues with DOF and noise). I wish it wasn't perpetrated as being some kind of universal rule-changer.
    But even the "rule of thumb" is invalid if you have surgeon's hands or are in the middle of a seizure.
  4. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    Are you wanting to start up another pointless fight? :D Google it, almost anywhere that camera shake rule of thumb comes up, it mentions crop factor. If I mentioned sources, we'd debate which sources were "reputable".
    Right, that's why it's a rule of thumb...
  5. Overread
    May 1, 2008
    24,079
    4,174
    UK - England
    Yes it a good rule of thumb to follow =- the other half is to perfect shooting stance.
    There are many ways to do this, here are a few:
    1) crouch down into the prone position (keep on foot on the ground and bend the knee- with the other leg place the knee on the ground - like shooting a gun.)
    2) breathing - a host of tips - though apparently you should press the shutter button at the very end of exhaling - there is a natural pause there.
    3) look about for a wall, post, fence, etc to either lean yourself on or to lean the camera on
  6. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    As already mentioned, it is a good rule of thumb (that does depend on format), but there are times when you can use a slower shutter speed and times when you should use a faster shutter speed.
    If you want ultimate sharpness it may not be fast enough - the effects of shake are not always obvious unless you put two images made with a high quality lens side by side at high magnification.
    Best,
    Helen
  7. sultan
    sultan TPF Noob!
    Mar 5, 2008
    302
    Mississauga, Ontario, Canada
    Thats the rule of thumb. It's a bit conservative and doesn't take IS into account. I say that you can ignore the crop factor because of it's conservatism. With, IS, you can go to half the speed (2x the time) easily and still be perfectly sharp.
  8. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    I usually find that I can shoot at much slow shutter at short focal lengths and my shutter speed requirement goes closer to the rule of thumb as focal length increases.
