Sponge1971
Hey all!
I'm a happy Canon (XSi & G10) owner.
I've got a HueyPro monitor calibrator, with a profile loaded all good.
I want to get separate components. Canon or Epson. A 'good' scanner and a 'good' photo printer (cd/dvds too!). My budget/needs are in the ~200-400 each range. I'm just a hack and print pictures for the fridge or my wife's scrapbook.
- to make life easy, color-wise, should I also buy Canon Scanner & Printer?
or
- should I go for specs/price and mix brands?
I'm open to all suggestions...
:chatty:Here's my long-winded, un-educated rationale for Canon only...
I kinda understand 'color space/color profiles' and how eyeballs/brains and pixles see/interpret the same light differently. Cameras, Scanners, Monitors and Printers all have different light sensing/emitting 'stuff'. My thinking is that Canon is *really* smart and has carefully 'configured' all the things they build to work seamlessly together.
eg. dump a Canon camera pic into Adobe. Print that pic on a Canon printer. Hold that pic up against your Canon computer monitor (I know, just pretend...). Heck, even scan that same pic with a Canon scanner...then compare both the scan and the camera original on that Canon monitor...They'll look identical, because Canon has handled all the color profiles and all that jazz to make sure they all follow through. They're all from the same 'maker' why shouldn't they all look the same? I read that Canon builds their own chip fabrication equipment, to make their CPUs and imagers, etc. To keep it *all* in-house and under their full control. Wouldn't These control freaks make sure of this kind of color-preservation flow too?
Anybody know if this is actually the case? Is it even feasable, or am I just dreaming? A simple yes/no/you're nuts will do. I'm sure this could spawn months worth of discussion on color profiles vs equipment vs. etc...
Anyway, like many others I'm considering a new Printer and Scanner. I've got an HP Photosmart C6108? all-in-one and I kinda hate it. (wireless networking doesn't, scanner autofeed is iffy, scanner chokes with Vista, prints are bleah, ad nauseum...). I'm scared of all-in-ones in general now (had Lexmark X83? previously...happily slam dunked it into the dumpster a couple years ago)
I've stuggled with that p.o.s. HP to get the color the same as I see it on my monitor, I'm just not getting there...and I'm fed up with the hiccups and crashes, anyway.
After all my searches, I'm wondering if maybe The Moderator might want to consider expanding this chunk of the forum to include 'Equipment' then sub the major pieces also. there's ton's of printer stuff here, but it seems scattered?
Thanks!
Eric
'photographer wannabe'
Toronto, Ontario, Canada
or
Thanks!
Eric
