Camera w/ grip and long lens... doesn't sit flat... is it safe?
Discussion in 'Photography Beginners' Forum' started by guitarlp, Jan 3, 2008.
  1. guitarlp
    guitarlp TPF Noob!
    Nov 28, 2007
    19
    So I purchased a battery grip for my Canon XTi camera and with the kit lens or my 50mm 1.8 lens it sits up correctly. But if I put on my 17-85mm lens (much longer and heavier) the camera falls forward. So, instead of having all the weight of my camera on the battery grip, some of the weight is on the grip and some of the weight is on the lens since the camera is leaning forward.
    My question is... is this safe for both the lens and the camera? I'd assume it would be safe as long as I don't let the camera fall forward and the lens smacks the table. But as long as I'm resting it down carefully each time it shouldn't be a problem right?
  2. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Shouldn't be a problem...but it's not ideal, if only because if anything or anyone falls onto the camera while in that position...it might damage the lens mount area.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    OMG TEH MOUNT WILL FALL OFF!!!!!!NO!!! DON'T DO IT!!! OMG!!!!!
    Seriously, you're fine, you can hit the side of the lens while it's on the camera and it will be fine.
    It's designed to take abuse (to an extent, of course)
