Can I repair this photo?
Discussion in 'Beyond the Basics' started by benjyman345, Dec 22, 2007.
  1. benjyman345
    benjyman345 TPF Noob!
    Sep 26, 2006
    152
    hi,
    A few of my photos have been ruined by water droplets on the glass of my underwater housing. I have uploaded a photo as an example.
    This photo isn't anything special but some of my other photos are and I want to try and salvage them. Is it possible to salvage this sort of spot in photoshop. If so could you please give me a detailed explanation how? (I am new to photoshop)
    Thanks
    #1
    [​IMG]
    #2
    [​IMG]
  2. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    I used the dodge tool, adjusting for shadow, midtones & highlights. This left me with a need for a hue shift back to green, some desaturation & lightness brought the values in range, BUT - the middle of the blob is quite decimated & will require some cloning. Cloning the beach was also easier that trying to repair damaged pixels.
    Basically cloning is probably the best technique. I did not post the quick and scrappy results because you have not specified a preference regarding the editing of your images. Also the second image was not there when I read your post.
    -Shea
  3. benjyman345
    Sep 26, 2006
    152
    Thanks!
    For these pictures, I don't mind if you upload the edited versions. Infact, if you don't mind would you be able too?
  4. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    At this resolution there is not much data to work with, but this may show you the possibilities. I created and merged several layers as part of the work flow, and ended with unsharp mask to cheat some detail into the washed out area. It is no where near perfect, but in 10 minutes this is what I came up with:
    [​IMG]
    Another approach would be to clone large areas onto a new layer and then subtract portions until it blends in. Or use another photograph (if you took one near this) and scale and tweak in a chunk of similar tree line.
    The second image is less troublesome, but with the red circle in it I'm leaving it up to you.
    -Shea
  5. kaiy
    kaiy TPF Noob!
    Nov 27, 2007
    69
    I played with these a little bit, and there is no easy fix. The only way to go is with cloning.
    [​IMG]
    [​IMG]
  6. Los Angeles
    Los Angeles TPF Noob!
    Nov 17, 2007
    174
    These are great but lets see the ones underwater.
  7. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I agree I want to see them too!! did you post them somewhere on the forum. I guess you don't want the advice to take the housing off when you get out of the water.
