Bitter Jeweler
- Joined
- Apr 27, 2009
- Messages
- 12,983
- Reaction score
- 4,993
- Location
- Cleveland, Ohio
- Can others edit my Photos
- Photos OK to edit
I'd like another helping of tripe, please.
Because it makes a better image?
And at the end of the day, a better image is all that matters. You keep repeating that it's abuse, that it's wrong, and unacceptable. But you can't seem to articulate why.
I already told you why but you don't seem to want to understand. The whole point is that he wanted to convey a sense of solitude, to tell a story (photojournalistic?). The man was not under the tree, so he decide to move the man. That is not what he actually observed. Presenting to an audience as such is not being truthful.
If he was taking the picture with intent of claiming that the scene was exactly as photographed, then yes, it is absolutely untruthful. But no where does he make that claim.
You're making a really broad assumption that photographs are truthful so long as they were not digitally manipulated. Would it have been acceptable if he had gone to the man and asked him to move to a different spot? In that case, the image accurately records the scene, but the photographer has acted to change the scene.
Were LAphoto documenting the scene as a journalist, both options would be unacceptable, because the rules are built around changing the scene, not around digital manipulation.
But I find it very difficult to fault someone for the second option in any other circumstance, and if you can't find fault in the second, the first is just another way to handle the same task.
Without question, learning how to get as much right in camera as possible is a critical aspect of learning to be a photographer. But that fact does not make digital manipulation wrong as a rule.
Yes, let's.
And it's "she".
I think it's an abuse if you want to call it that. I say so because you didn't really capture what you "saw". I doubt if you enter such a picture into a contest, that it would be allowed. Now of course, you could set it up in such a manner that the man was actually walking by the road....
As to the OP, I guess, the only comment I have is for the newbies to get as much correct in camera as they can. I see no joy in spending countless hours in front of a computer when you could use those times to practice photography skills.
Personally, I see absolutely nothing wrong with what was done here. If LaFoto hadn't mentioned that the guy was moved, I would have never noticed. Since it was mentioned, it's easy to spot where he was cloned. In the end, all that matters is the end result, the final image. I would never have made a second glance at the original photograph that LaFoto described, since having the man on the same side as the tree wouldn't have looked very good. This way, it's at least an interesting photo.
Whether it would be allowed into a competition isn't really the point. Every photo competition has different rules, and even categories. If LaFoto had taken a couple more minutes with the PP, you would likely never be able to tell the man was moved.
That's not the point. He posted the photo asking if we think by moving the person whether or not that would constitute an abuse. To me, this type of photograph is supposed to tell a story. Something along the line of "while on a bus, I saw the man walking alone along the road, and it made me think of solitude and I took the photo". If you have to go to this degree and force the photo, then it lost it's mystique, and there would be no sense of connection to the scene.
Tell me, what's the difference now, between making colors pop, and smoothing someone's skin, and moving the man in the photo? When you saturate those colors, aren't you forcing a new interpretation of the image onto the viewer? When you smooth that skin, are you conveying what the scene actually showed? What if LaFoto had been able to ask the man to move and been able to retake the shot like that? Would that have been acceptable even though the end result was the same? And why would that be acceptable, but manipulating the image to gain the exact same result is abuse? Cropping is a technique to correct a composition mistake. Is that abuse (since you implied that correcting composition in post is abuse)?Now, I think it's ok to use Photoshop for such thing as making colors pop, smoothing someone's skin for instance, but I would never recommend it to a newbie as a mean to correction a composition. I see quite a few C&C where a newbie is advised to clone out, say, a branch sticking out from someone's head. The problem with such an advise is that it does not convey the proper message to the newbie, and that is think before you click that button on the camera. It's a fine delicate line we need to walk.
I don't quite understand why it is alright to smooth someone's skin but not to move someone from one side of the image to the other. Either way you are changing the story, you are not being truthful.
LaFoto is not a PJ so she has no need to stick to the truth. Talking about the truth, photography is not very good at telling it anyway. Or at least, at conveying it the way it is in real life.
A great example of that is Eddie Adams' famous Vietnam photo that tortured him to the end of his days and made the life of General Nguyễn Ngọc Loan a big pita. Here's how he talked about his photo to Time: "The general killed the Viet Cong; I killed the general with my camera. Still photographs are the most powerful weapon in the world. People believe them; but photographs do lie, even without manipulation. They are only half-truths. ... What the photograph didn't say was, 'What would you do if you were the general at that time and place on that hot day, and you caught the so-called bad guy after he blew away one, two or three American people?'"
Not always! Sometimes, action shots come to mind, you should allow yourself some leeway. The point I was making, the gods designed those sensors for optimum exposure, contrast and color. It just seems a sacrilege how often we constantly go against them.You shouldn't rely on PS to crop your images. You should get it right in camera. :greenpbl:
smoothing someone's skin is also a "lie" if you will, but in this case the client most likely requested and know that the image is being manipulated.
Well, White, you can see what the all untouched photo (as it was shot by me through the bus window in speeding past the scene) looked like. I'm showing it, too.
The situation I was in did not give me much opportunity to get everything so right in camera that the end result would be one pleasing to the eye, so for reasons of "Can I do it?" more than any other I played with the photo a little, by picking up the man and putting him 12 steps ahead of where he was.
And I'm only presenting this photo of mine to an "audience" for the sake of this discussion.
