Can you explain Macro extension tubes please?
Discussion in 'Beyond the Basics' started by Hair Bear, Apr 8, 2007.
  1. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    Not sure if I have the correct section but
    Total newB question, but how do Macro extension tubes work?
    Can you get sets that do carry all the aperture signals to the camera or do they always render the lens a totally manual item?
    Good ones, bad ones?
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Best tubes are bellows. Novoflex Auto Bellows. Not cheap, though.
  3. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    12,781
    2,399
    Wichita, Kansas, USA
    Tubes are just that, tubes. they have no glass in them. Some tubes will allow for full auto operations some do not. With a dslr you will want to have the ability to select the apeture. For me focus is done manually as in macro work it is critical.
    The tube places the lens further from the film/sensor plane. By doing this it allows for the ability to shorten the minimum focusing distance. (you can get closer to you subject) I won't go into the math. With tubes you loose infinity focus.
    As for bellows, they are only good for static macro photography. Very unwieldy and hard to use in the field. They are expensive and are manual focus, and ofter manual apeture as well desigend to use older 35 mm lenses. The Novoflex auto bellows do allow for the use of newer camera controled apeture lenses but at $600 + a little pricey.
    The best INHO way to go is with a good macro lens. They will usually do 1:1 macro and are usually high quality lenses for standard use. You can even buy dedicated macro lenses that will to 5:1. Very close indeed. The best place to learn about macro is here: http://www.macrophotography.org/index.php
  4. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    Thanks for the info and the link, very interesting.
    I was trying to see if i could do some macro work with my lenses a little cheaper than buying a macro lens but I'll put one on my wish list!
  5. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    I recently got a set of Kenko Auto Extension tubes, and they work really well while still allowing the camera to control the lense for aperature and focus. You do loose light though, so may need to manual focus as you use more tubes in low light.
    I got them because I can't afford a dedicated macro lense right now. I purchased them from HongKong for less than $100 US shipped to my door.
    Here is link to a thread I started when I tried them: http://www.thephotoforum.com/forum/showthread.php?t=77384
    Cheers
  6. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    Thats cool as they make all Nikon lens's in to macro, £54 + 16 shipping £70 humm just need to check Macro lens cost
  7. auer1816
    auer1816 TPF Noob!
    Jan 14, 2007
    139
    Well said.
    I first had a 25mm Kenko extension tube that I used with my 18-200 zoom. I had a lot of fun with it, but I wasn't getting true macro. Plus you can't focus out to infinity with a tube attached.
    So I bought a 105mm 1:1 macro, and I love it. I can do macro work AND regular shots without changing the lens. I can also attach the extension tube to the macro for greater than 1:1 magnification. Lots of fun.
  8. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    As I cant afford a dedicated macro lens then a set of Kenko tubes might be the way to go. Then later if I can get a lens I can still use them on it.
  9. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Another recommendation for a dedicated macro lens here... I don't have one at the moment and while extension tubes or lens reversal are fun they're not all that practical; very limiting working distance and most lenses don't stop down as much as you'd want from a macro lens. Previously I had great results from a Tamron 90mm Macro, and of course there are Sigma or Tokina offerings, plus you may be able to use older Nikon lenses depending on your camera, so in fact a good macro lens may not be much more expensive than those £70 extension tubes. P.s. that sounds like a lot for extension tubes; do they have electronics for open-aperture metering?
  10. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    If you don't already have one as a part of your extension tube set, you might consider getting a lens reversing ring. You use this when you want image size:subject ratios greater than 1:1.
do macro extension tubes work
do macro tubes allow 1:1
explain extension tubes
how do extension tubes work om my macro lens
how do macro extension tubes work
how do macro tubes work
how do photo extension tubes work
how does a macro extension tube work
how does a macro tube work
wh cant i focus my macro extension tube set
