To what end? Is there an application you want to run faster on your camera?
1/8000 isn't fast enough? How fast do you think you need your shutter to be?To what end? Is there an application you want to run faster on your camera?
Faster shutter speed would be the main thing. With the faster shutter the sensor will need more gas as well.
Right?
Right?
I guess what I meant FPS. Like 10+ frames a second. I'm only at like 5.6 with my 50d.ummm, just wondering here ... has anyone ever used over 1/4000 of a second for an exposure? If so, we're you outside of a controlled studio and were you shooting anything other than a bullet?
Honestly man, there are very few situations that require more than, lets say, 1/1000 of a second shutter speed ... if you get that high than light becomes the issue and not the camera (most can do 1/4000 and some even higher) ...
As for "OVERCLOCKING" the sensor, you will only increase the amount of "Noise" and would probably render the image virtually useless ...
What are you shooting that you feel the need to do this?
No. The shutter on the 50D couldn't handle it. It would take more than simple "over clocking" (whatever that may be in terms of camera equipment) and would require completely redesigning the existing system.I guess what I meant FPS. Like 10+ frames a second. I'm only at like 5.6 with my 50d.ummm, just wondering here ... has anyone ever used over 1/4000 of a second for an exposure? If so, we're you outside of a controlled studio and were you shooting anything other than a bullet?
Broad daylight and f1.4has anyone ever used over 1/4000 of a second for an exposure? If so, we're you outside of a controlled studio and were you shooting anything other than a bullet?
I have said this many times " FPS does not matter timing is more important because you only need one frame to get the shots"
