Cannon 85mm or Tamron 24-70???
Discussion in 'Photography Equipment & Products' started by dogk1cker, Dec 31, 2006.
  1. dogk1cker
    dogk1cker TPF Noob!
    Sep 30, 2006
    5
    I guess there is not much more to say about the 85mm but I wonder about the Tamron. The Tamron a few dollars more but I wonder if I can get the same quality as the 85mm. If you have used both, please post your experience. Thanx.
  2. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    The basic rule of thumb is a prime will always be sharper than a zoom. A prime only does one thing. Take pictures at what ever focal length it is designed to be. Zooms are designed to do several things as well as is possible within those limitations.
  3. Cuervo79
    Cuervo79 Guest
    the best question is what are you going to shoot, zooms are very helpfull in tight spaces and for digitals, primes have better quality but you have to move phisicaly.
    I bought the 85 1.8 and I love it although I mostly use the 50mm 1.4 because of the multiplying factor in my rebel.
    I got this gig on covering a small beauty show and both the 85 and the 50 shined, the light was enough for me not to use any flash and at F4 the images where very sharp (although you need to be carefull with depth of field)
