canon 10D
Discussion in 'Digital Discussion & Q&A' started by Ben613, Jul 19, 2006.
  1. Ben613
    Ben613 TPF Noob!
    Jul 19, 2006
    7
    I have trouble with my 10D when it comes to white balance. I will set it for the white shirt of the client and yet their faces end up not having the right tone in the end. Thus, I need to fix it in Photoshop. Any suggestions?
  2. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    It would be much easier if you shot raw. You set white balance to the type of lighting your using. How did you set white balance for a shirt?
  3. malweth
    malweth TPF Noob!
    Jul 10, 2006
    43
    Rhode Island, USA
    Wouldn't manual white balance work off a pure white shirt?
    I've just read books though... my camera (D50) comes Friday!!
  4. ksmattfish
    Aug 25, 2003
    7,021
    34
    Lawrence, KS
    Is your monitor calibrated? Maybe the photo is fine, but just looks bad on your monitor.
    I think my 20D sets the WB too yellow. I stopped testing for WB in the field since I'm usually shooting RAW, and I always ended up adjusting it from what the camera recommended anyway. Now I just leave it on daylight balance most of the time.
  5. Ben613
    Ben613 TPF Noob!
    Jul 19, 2006
    7
    Thanks. How do I calibrate the monitor?
    What I usually do is have 2 elinchrome 500's set up at 45 degree angles with reflector umbrellas (white inside). Then, I take a shot of the shirt with the camera white balance set for flash. Then, select that shot to tell the camera that's what white should be and custom white balance it from there. Maybe it is my monitor???? I usually shoot at the highest JPG because I furnish a CD of images to the client almost immediately and am done. When not doing that, I could shoot RAW - doesn't that essentially mean that I lose no data and photoshop all the images . . .time consuming - how can I get it right from the beginning???
    Thanks everyone.
    Ben
  6. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Just do some WB bracketing. If you have to shoot JPG just do a couple of shots at different WB settings. If you have umbrellas and everything set up why don't you just do some test shots on your self. It's not like the WB is going to be changing
  7. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Even though things appear to be white there is going to be some color in it. Adjusting the white balance could give it a cooler or warmer look
  8. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    Properly calibrating your monitor requires a hardware device to read the output. I recently purchased the Spyder2 calibration package and the difference is significant.
    Shooting RAW typically does mean more time in post production but it does offer more flexibility. You can batch process the files though. So, if all your shots are done under the same lighting, you can adjust one image any apply those adjustments to all the other images automatically. Sure you could apply a color adjustment to a JPEG in Photoshop but then you are altering (damaging) the image. Adjusting WB of a RAW file does not degrade the image.
    Although, it seems you are doing the right thing by setting a custom WB for your shoot. Maybe try using a white card (or grey card) to set the WB rather than the client's shirt.
  9. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Are you filling the frame with the shirt? Don't overexpose it either. A blown out shirt, devoid of detail, can give a false reading.
  10. ksmattfish
    Aug 25, 2003
    7,021
    34
    Lawrence, KS
    And if the shirt is at all transluscent then color from the subjects skin could be affecting wb.
    If you are going to all the trouble of a studio strobe set up then get a gray card to use instead of the subject's shirt.
  11. Ben613
    Ben613 TPF Noob!
    Jul 19, 2006
    7
    Thanks everyone. I'll try these things.
    Ben
  12. Ben613
    Ben613 TPF Noob!
    Jul 19, 2006
    7
    A BELATED THANK YOU FOR THE ADVICE ON CALIBRATING MY MONITOR.
    DO YOU KNOW HOW TO DO THAT SO THAT THE MONITOR IS SET RIGHT WITH THE CAMERA?
    I HAVE NO CLUE.
    BEN
wb canon 10d
