canon 20D noisy at iso 100? :S
Discussion in 'Photography Equipment & Products' started by UUilliam, Sep 16, 2010.
  1. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    here is 2 shots from my canon 20D which is known for its good iso performance,
    I admit it is really good at 1600 compared to other cameras, it is usable at 1600 however, the iso at 100 is a different story :/
    100% crop
    [​IMG]
    full image
    [​IMG]
    has been slightly edited in lightroom (resize and fix colour.)
    I suppose SOME of it might be from the film... but it was ilford ASA 100 I used, it doesn't have any visible grain on the contact sheet...
  2. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    You need to post some more EXIF data. From the image though, it looks underexposed. Images can become noisy if that is the case, no matter what ISO you use. Just not enough light for the sensor to register properly. At lower ISOs, you need a lot more light.
  3. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Yes, I underexposed by 2 stops, simple for the fact I was on f2.8 and needed a shutter of atleast 1/60 (had no tripod or anything.)
    but surely it shouldn't create that much noise?
    lens was 85mm f1.8 (canon.)
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I think it should be noisy if you under expose the image. You will see more noise if you try to correct the exposure in PP.
  5. AdrianC
    AdrianC TPF Noob!
    Aug 1, 2010
    155
    Edmonton
    According to the exif data, that picture was shot at 1600 ISO.
  6. xsouthpawed
    xsouthpawed TPF Noob!
    Nov 8, 2009
    71
    but my 10D isn't noisy at all! and it's the predecessor ;)
  7. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    How about instead of basing your whole camera off this one image. You go outside on a bright day, take a picture and see what happens.
  8. prodigy2k7
    Apr 22, 2008
    1,667
    22
    California, USA
    Yep. I see that too.
    "ISO Speed Ratings = 1600"
  9. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    oops :$ i must have forgot to change i back to 100iso :( DOH!
