Canon 24-150mm lens question
Discussion in 'Beyond the Basics' started by tkphoto, Feb 14, 2008.
  1. tkphoto
    tkphoto TPF Noob!
    Jan 14, 2008
    4
    I am getting ready to buy a Canon 5D. B&H has the body w/the 24-105mm f/4L IS USM lens for $2750. Does anyone have this particular lens? If so, what do you think of it? Should I get this lens or just get the body and buy another lens? I've currently got the DReb XT, its kit lens and a Tamron 28-75mm lens, which I use all the time.
    Any suggestions?
    TIA!
    Tonya
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I don't own that lens...but it's got a great reputation...as do most L lenses.
    The 'pros':
    -Great range on a 5D
    -IS
    -L build and image quality
    -not overly big or heavy
    The 'Cons'
    -The max aperture is only F4, many people opt for the 24-70 F2.8 L instead
    -It's rather expensive
    If you are happy with your Tamron 28-75, there is no reason you can't use that lens on a 5D. It will have a wider filed of view on the 5D (similar to your kit lens on your D Rebel).
  3. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Got the 5D, and one of my lenses is the 24-105 L.
    While it is not the sharpest lens I ever had, it is certainly the most versatile lens I ever had on any camera.
    I can live with it not being f/2.8, distortion at the wide end is quite noticeable thought. If I do architecture, I hence most of the time correct distortion in postprocessing. For people and landscape that is not really an issue though.
    It does show a bit chromatic aberration at the wide and the long end, but much less than most non-L zooms. Also, this is easily corrected in the RAW converter anyway.
    The IS is very handy, in particular at 105mm. And with those 35mm extra over the 24-70 I can often leave my 300mm lens in the bag when it comes to get some quick animal or people shots from a not so far distance.
    To summarise, I would like it to be a bit sharper, in particular at f/4, but it is my most used lens due to its versatility.
    EDIT: I should mention though, that when I say I want it sharper, I am comparing to high-end lenses, in particular primes. I have a bit of an IQ fetish here ;)
  4. tkphoto
    tkphoto TPF Noob!
    Jan 14, 2008
    4
    Thanks so much for your help guys! I appreciate your time!
    Tonya
  5. snedelchev
    snedelchev TPF Noob!
    Feb 16, 2008
    41
    hi, i got my a week ago - canon 5d with 24-105 L. The lens is 700 $ in kit insteed 1000 $. I'm so happy about it. I have some pics at my blog at 1600 iso too.
    so go forward
    stef
canon 24-150
canon 24-150 lens
canon 24-150mm
lens canon 24-150
