- Joined
- May 1, 2008
- Messages
- 25,422
- Reaction score
- 5,003
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
The 300mm f4 is a very good lens, but you have to remember its about more than the speed of the aperture. From all I have seen comparing the 300mm f2.8 and the 300mm f4 (I belive Juza has spoken of it in some of his reviews, though I can't recall if he has done a comparison of both) the 300mm f2.8 is superior to the f4 especailly when combined with teleconverters. This refers to both the image quality and the auto focusing speed.
In addition remmeber that the f4 lens will lose auto focus on a canon DSLR (f4 minus two stops is f8 which is smaller than AF works with - it stops at f5.6 unless you use a 1D line body). Even though you can tape pins and trick the AF to continue to function accuracy and speed drop (especailly in more limited lighting) and there is far more chance for the setup to hunt for focus.
The 300mm f4 is a lot lighter and has a greater magnification factor for close up shots, but for straight telephoto use whilst its impressive the 300mm f2.8 is more so.
