Canon 30D Picture style settings
Discussion in 'Photography Beginners' Forum' started by AE86, Jun 17, 2008.
  1. AE86
    AE86 TPF Noob!
    Jun 17, 2008
    23
    Victoria Canada
    Hello for all of you using the 30D have you played around with picture style settings? (Standard, Portrait, Landscape, etc etc.) Did you leave them as they were out of the box? Tweak them a little? or did you just make user defined ones?
    I ask this because I'm having trouble capturing true sunsets. The colors look either not as intense or unnatural. This happens mostly on the sunsets with firey reds and purpley-blues (witch i find the most exciting and dramatic:er:)
    I have experimented with exposures + and - with out much luck. Or is this a question of white balance? I usually shoot on the sunlight WB with sometimes shooting on the tungsten to give some crazy blues. I've even tried every WB setting just for kicks. But i still cant get it to look how it actually looks, which get me pretty bumed out when i walk away from a shoot unsatisfied.
    One thing i don't really play around with is the color temp.....
    I'm shooting with Canon 30D with 17-85mm IS lens with a tiffen uv/haze filter as lens glass protection.
    Any help would be great!
  2. Mary-Beth
    Mary-Beth TPF Noob!
    Jun 16, 2008
    32
    The problem is probably the dynamic range, AE. It is too great for the camera to be able to capture the extremes in the one exposure. You may need a tripod, and either a GND filter, or applying HDRI to merge a bracketed sequence of exposures.
  3. AE86
    AE86 TPF Noob!
    Jun 17, 2008
    23
    Victoria Canada
    Thanks for the info. I use my tri-pod if i have it. Also i do bracket the shots, but i haven't played around with HDR image software.
    As for being to dynamic i guess that could be the cause, but i also find other shots are not a vivid and full of color like i think they should be.
    I would like some 30D users input on if they have changed any of the picture style settings and if so to what and where they find it works best on.
  4. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    The vividness of the color has nothing to do with "being too dynamic". It has to do with saturation and almost always is bumped up in PP.
