Canon 30D
Discussion in 'Digital Discussion & Q&A' started by sean300, May 18, 2006.
  1. sean300
    sean300 TPF Noob!
    May 15, 2006
    14
    Kansas City, MO
    I just realize that the setting on my camera only shoots pictures with a 72 dpi resolution. How can i raised that? I have it set to Large/Fine format. What else is there? My digital rebel and powershot s500 has a higher dpi resolution than that. Please help me out. Thanks
  2. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    it makes no difference. My 20D shows images at 72dpi straight from the camera. it's simple enough to change to to whatever you wish in whichever post processing package you use. The 20D cannot be changed from 72dpi so i presume the 30D will will be the same.
    I'm sure someone will explain the technicalities.
  3. Digital Matt
    Jan 30, 2004
    5,346
    65
    Santa Barbara, CA
    DPI is only important in the printing stage. There's no difference between a 2400x3000 72 dpi image, and a 2400x3000 300dpi image, until you print it.
    At 72 dpi, it would print 33.333 x 41.667, and at 300 dpi, it's print 8x10. The 8x10 would look better, because there are more dots, closer together.
    As said, you'll just have to change it in your image editing software prior to printing, where you should be sizing and cropping the image (if need be) anyway.
  4. RCollins
    RCollins TPF Noob!
    Apr 7, 2005
    10
    I am using CamReader to automate my import workflow.
    CamReader automatically correct the resolution of images to 300 DPI plus performs numerous of useful tasks: autorename files, autorotate images based on EXIF orientation tag, correct file timestamp, backup my picture to my external fire-wire drives and copyright my pictures. Just try it out and you can't imagine your workflow without this program. I owned the Canon 30D and CamReader the only one program which supports direct import from my camera.
    CamReader home page
30d dpi
canon 30d 300dpi
canon 30d dpi
canon 30d dpi setting
canon 30d dpi settings
canon 30d resolution dpi
canon eos 30d dpi
how to set dpi for a canon eos 30d
replace canon 30d forums
setting dpi canon 30d
