Canon 50D problem
Discussion in 'Photography Beginners' Forum' started by Mick-1, May 18, 2010.
  1. Mick-1
    Mick-1 TPF Noob!
    May 18, 2010
    Hello all, I hope I'm posting this in the right spot, so here goes.
    I have a canon 50d and have been using it for time lapse using the canon TC-80N3. I have a 16gb card and am using the S3.7m quality setting. The exposure is 15sec and on the timer, the self timer is 4hrs with the interval at 25 sec. The Exp count is set at 00
    The problem is that the camera stops shooting after about 400 shots even when the card is far from full, in the top right corner of the LCD screen the [999] flashes and nothing can be done unless I pull out the battery and replace it, then I can start again. Though by this time what I wanted to capture is long since gone. All this while the timer continues as if nothing has happened.
    Is there a setting that I can change on the camera or the timer? Am I doing something incorrectly? Any help will be appreciated, many thanks,
    Mick.
  2. KmH
    Apr 9, 2009
    40,536
    5,541
    Iowa
    "....the LCD screen the [999] flashes and nothing can be done unless I pull out the battery and replace it......"
    There are 4 numbers that can be displayed there:
    1. Shots remaining
    2. Shots remaining during WB bracketing
    3. Self timer countdown
    4. Bulb exposure time.
    999 is one of those and it doesn'rt seem to represent #'s 1 & 2 above.
    I suggest you look through your users manuals for both the intervalveometer and the camera.
  3. Mick-1
    Mick-1 TPF Noob!
    May 18, 2010
    OK, cheers, Ill give it a go.
