Canon 50D Trouble Please Help
Discussion in 'Digital Discussion & Q&A' started by abrewerphotography, Dec 19, 2009.
  1. abrewerphotography
    abrewerphotography TPF Noob!
    May 24, 2009
    17
    KY
    I have a canon 50 d that is only 2 months old. I have been having trouble when using it in auto that the flash will not pop up, and in the image produced is all black. Also when I go into av or the other modes it does the same thing. I am getting only black images, and if the flash does pop up when I manually push the button, the image is still very dark. Any suggestions? I am so frustrated b/c this is a virtually brand new camera!
  2. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    I think you should just give me the camera.
    (the lens hood isn't on is it?)
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I think you mean lens cap :D
  4. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    OP, what about when you take photos during the day (outdoor)?
  5. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    yeah, wasn't thinking... lens cap.
    Also, when you go into auto are you talking about the P mode, or the green box?
    one other thing to check is when in AV do you have exposure compensation at even? or is it way into the negative range?
  6. sinjans
    sinjans TPF Noob!
    Jun 29, 2009
    346
    Newfoundland, Canada (yes by')
    have you reset your settings to default yet? if it wont pop up when it is supposed to i.e. green mode, or portrait in less lighting then it probably needs to be sent to canon.
    (EDIT) also what lens do you have on it? is their a round alert light going off in the view finder?
  7. Crosby
    Crosby TPF Noob!
    Mar 7, 2008
    269
    Arkansas
    OP, Have you read the book?
  8. William Petruzzo
    William Petruzzo TPF Noob!
    Aug 22, 2008
    635
    Washington DC
    If you're not getting an error notification, I'd bet there's a setting somewhere you're missing. I'd try resetting to defaults, then spending an afternoon studying the manual to the last drop.
    If that takes you nowhere, off to Canon it is!
