Canon 5D HELP!!!
Discussion in 'Photography Beginners' Forum' started by dak1b, Jul 9, 2010.
  1. dak1b
    dak1b TPF Noob!
    Jun 30, 2009
    1,554
    Northern California
    Hello All!
    Just recently purchased the Canon 5D. Was working fine..now for some reason it won't take pics? seems like the shutter isn't releasing or something? When I click teh shutter to take a picture it seems like it only goes halfway down and nothing shows up on the lcd...was just working fine a minute ago..wat am I doing wrong here? Please HELP!!!
    I think I might have a setting wrong? every time I go into menu and scroll I hear the shutter clicking.
    please help i'm a noob to the 5D:blushing:
  2. jakedoza
    jakedoza TPF Noob!
    Apr 21, 2008
    120
    Austin
    turn it off.. pull the battery and try it again.. my 40D does that sometimes.
  3. dak1b
    dak1b TPF Noob!
    Jun 30, 2009
    1,554
    Northern California
    didn't work and I took the memory card as well and switched it with a new one.
    is there a setting i have wrong?
    it clicks every time I change the battery, swap memory cards...etc..help
    I'm using the Canon 100mm Macro lens by the way.
  4. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Who knows what setting you may have misconstrued.
    Go back into the settings and put them to default, see if that helps
    It sounds like you may have touched the live view button. Check that out to see if it is in an inbetween position.
  5. dak1b
    dak1b TPF Noob!
    Jun 30, 2009
    1,554
    Northern California
    Put settings back to default...didn't help
    and there is no live view option on the Canon 5D MK I
    other solutions?
  6. dak1b
    dak1b TPF Noob!
    Jun 30, 2009
    1,554
    Northern California
    hmmm ok now it seems like its working.
    my lens was set on 0.48m to infinity
    switched it over to 0.31m to infinity and its working now.
    is that was caused this issue? does that sound right?
    would any lens setting or aperture/shutter speed cause this issue on the 5D?
    thank god!!!!! i was a little worried.
  7. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    Weird. First thing I thought was that maybe you had turned on mirror lockup, which means that when you press the shutter release the mirror flips up but the shutter doesn't open until oyu press the shutter button a second time.
  8. dak1b
    dak1b TPF Noob!
    Jun 30, 2009
    1,554
    Northern California
    that could of been the issue?
    at first i thought the shutter was failing...:( but with only 3k actuations that was highly unlikely.
    but wtev it was it seems like my 5D is running great!:thumbup:
  9. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Glad to hear you are back in action!
