Canon 5D MkII and 300 f/2.8L
Discussion in 'Photography Equipment & Products' started by phototrek, Mar 19, 2009.
  1. phototrek
    phototrek TPF Noob!
    Mar 10, 2009
    50
    I am thinking about getting the 5D2 and the 300 f/2.8L IS lens. I will be using this lens to take landsacpe and/or wildlife photos. I also might get the 1.4 converter. I know this is a great lens but is it good for landscape photos or should I get other lenses? I already have the 24-70 f/2.8L, 70-200 f/2.8L and the 100-400 f/2.8L.
  2. tsaraleksi
    tsaraleksi No longer a newbie, moving up!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    Given your lens lineup I think a 300/2.8 would be a good addition. If you need the focal length, that lens is about as good as it gets.
  3. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Usually landscape photographers want something a bit wider than 300mm dont they?
  4. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    I wish the 100-400L was 2.8!!
    Anywho, 300mm is a bit long for landscape,but would be a great low light wildlife lense.
  5. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    I have shot landscapes with lenses anging from 17mm all the way up to 600mm. Its not always about being wide. Its about getting the comp and perspective. I agree that the 300 would fit in nicely. It will be a little short for wildlife, especially on a full frame sensor. The teleconverter will help, but personally I only use them if I have too.
  6. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    The 17-40mm f/4L is a better landscape lens for the 5Dmk2. One of the lowest cost L class lenses.
  7. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    For landscape (non moving subject, generally good light, on a tripod) would it not make more sense to get the 300 f/4L? I know it isn't as ooooo.. and aaaahhh as the f/2.8 glass but it is lighter (half the weight) and easier to pack. Landscape photography is all about getting to a location.
    Oh and yes... the 300mm is a bit short for wildlife.
  8. uplander
    uplander TPF Noob!
    Mar 22, 2008
    536
    S.E. WI.
    Just explain to me why the 300 would be short on a full frame as opposed to a crop sensor?
    The image is the same but only the edges are cropped. Splain Lucy!!!
  9. usayit
    Nov 15, 2003
    9,523
    346
    Yes you are correct BUT on a full frame, you need a longer focal length to fill the frame with the same subject.
  10. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    Yep, what usayit said. For the type of wildlife shooting I do, 300mm is way to short on crop sensor as well.
  11. KvnO
    KvnO TPF Noob!
    Jan 12, 2009
    208
    Michigan
    Personally, I'd go for something on the wide side. You've already got the telephoto end covered pretty well. For landscapes, I think you might be better off/happier with something wider than 24mm.
  12. phototrek
    phototrek TPF Noob!
    Mar 10, 2009
    50
    Yeah, I was also thinking about getting the 16-35 f/2.8L. The reason I was thinking about the 300 f/2.8L and the 1.4 converter is because I can't afford the 500 or 600 f/4L lenses.
