Canon 70D
Discussion in 'Canon Cameras' started by Mchedgerphotography, Oct 24, 2017.
Tags:
  1. Mchedgerphotography
    Mchedgerphotography TPF Noob!
    Oct 24, 2017
    8
    Rhode Island
    Hey there! So, im a bit new with photography and even working with my canon 70D functions. I noticed the quality of the pictures aren’t as sharp when I post them online compared to my camera screen. I know the MP is 20ish.... Now I have used Automatic a lot ( on the body) manual on my canon 18- 135mm IS STM lens. My goal is ito start playing with manual but if I do take automatic shots; can I get a better quality photo?
  2. TCampbell
    TCampbell Been spending a lot of time on here!
    Mar 31, 2012
    3,388
    1,454
    Dearborn, MI
    If they are sharp on your computer but not sharp online then either you or your online hosting site has resampled at a lower quality.
    This is a somewhat common on Facebook. You upload high quality... but to save space, they re-sample everything to a much higher compression and you lose image resolution. The result is a version of your image that doesn't nearly as good on Facebook as it did on your computer.
    I know of no work-around other than to post the image to another website that doesn't re-sample the images at lower quality ... and post a link.
    • Agree Agree x 1
  3. CherylL
    CherylL No longer a newbie, moving up!
    Aug 6, 2012
    729
    334
    near St Louis
    I had the 70D and the 18-135 lens. The 70D is a very good camera. The lens is okay, but isn't as sharp as a prime. What you see on the back of the camera screen is very small and you can't really gauge a photo's sharpness. Practice with the different focus modes. The problem may be with using manual focus on the lens. The camera's touch screen does a great job when you select your focus point and keep the lens on AF.
  4. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,409
    4,112
    Iowa
    I think the photo will generally look sharper on a small display, such as your camera's LCD. When you look at it in a larger size, the resolution is going to start to look more "pixelated". If you printed that same file at a substantially larger size, it would look even more pixelated.
    If sharpness is important above other qualities, then be aware that there are several factors that will affect sharpness.
    Camera movement and/or shutter speed. This is easy to verify by some testing. Mount your camera on a tripod and take a shot with the same settings. If that one is sharper, then it probably is mostly camera shake. Good technique, coupled with faster shutter speeds will help a lot.
    The lens. Some lenses are just naturally sharper than others, and the resolution may be different at different apertures. Test this by borrowing a different lens to compare.
    Some attachment on the front. I think you have a filter of some sort one the front of your lens. Test that by removing the filter and take the same shot, using the same settings as before. If the new version is sharper, then there's your culprit.
    As has been mentioned; websites sometimes compress images when you upload them. Nothing you can do about that except choose another hosting site.
    And, of course, it could be combination of all the above. You know; 50% one, 20% another, 30% the other thing. In that case, you will have to choose where to start first.
    BTW: a 20MP file can print a fairly large print, so don't run out and order a camera based on only the sensor pixel count. 20 is good for nearly every kind of photograph. It's only when you want to print a wall-sized mural that the pixel count can be important.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,513
    15,229
    USA
    On-screen images typically need to be down-sized from the camera-size, and some sharpening needs to be applied to the images files, so that they look "right" on-screen, at say 1,900-pixels on the long axis.
    • Agree Agree x 1
