Canon 7D Gymnastics Setting Recommendations
Discussion in 'Canon Cameras' started by ALmomof3, Feb 25, 2013.
  1. ALmomof3
    ALmomof3 TPF Noob!
    Jan 5, 2013
    11
    Can anyone suggest some settings for a canon 7D,using lens 50mm/ F 1.4 USM , for the indoor sport of Gymnastics- no flash allowed.
    Thanks!
  2. rexbobcat
    rexbobcat Been spending a lot of time on here!
    Nov 28, 2011
    4,946
    1,903
    United States
    Meter for the available light. Keep your shutter speed high.
  3. Majeed Badizadegan
    Majeed Badizadegan TPF Supporters Supporting Member
    Jul 14, 2011
    4,173
    2,540
    Probably at least 1/400 for the shutter speed. I wouldn't go under 2.5 with the aperture. f/4 if there's plenty of ambient light. I'd recommend using high speed burst paired with AI servo back button focusing so you don't miss the moment, or focus.
    • Like Like x 1
  4. TCampbell
    TCampbell Been spending a lot of time on here!
    Mar 31, 2012
    3,354
    1,431
    Dearborn, MI
    At f/2.8 you'll get a little over 8' of DoF if your subject is 25 feet away. If you drop to f/2 then the DoF reduces to a little shy of 6'.
    Note that this is for 25' distances. If you are only 20' away, then the DoF for f/2 is reduced to less than 4' (about 3.7 feet). So while you have a lens that can collect a lot of light, the DoF will get too narrow to catch your entire subject in focus if you're too close.
    A shutter speed of 1/500th will freeze all but the fastest actions. It's generally considered fast enough to freeze action in most sports and, often, you can get away with speeds just slightly slower.... possibly as slow as 1/250th.
    I've noticed that high-school gymnasiums may require ISO 3200, f/2.8 and then give you shutter speeds between 1/400 & 1/600sec. Professional sports stadiums often have better lighting and may allow you to drop the ISO considerably lower (for less noise.)
    Note that those shutter speeds are for action. If you're shooting non-action shots (before/after competition) then you can drop the shutter speed down to about 1/80 sec. and cut your ISO for less noise. With a 50mm lens, you shouldn't see motion blur from a hand-held shot at 1/100th as long as you're trying to be steady and keeping your elbows under the camera and planting them on your belly.
  5. Light Guru
    Light Guru Been spending a lot of time on here!
    Apr 27, 2011
    3,310
    656
    Salt Lake City, UT
    And how do you plan on getting close enough to shoot gymnastics with a 50mm lens.
    • Like Like x 2
  6. ALmomof3
    ALmomof3 TPF Noob!
    Jan 5, 2013
    11
    I had no problem this weekend shooting with my 50mm, depends on facilities & setup. Sat on front row & got these: $ImageUploadedByTapatalk1361867265.087541.jpg $ImageUploadedByTapatalk1361867277.368911.jpg $ImageUploadedByTapatalk1361867287.729651.jpg
  7. imagemaker46
    imagemaker46 Been spending a lot of time on here!
    Mar 9, 2011
    4,422
    1,705
    Ottawa, Canada
    Seems you have already shot gymnastics, why are you looking for settings? The ones you posted are dark and need a crop, 50mm is not the best lens to shoot with, but they don't look as bad as I would have expected shooting gymnastics with a short lens.
  8. ALmomof3
    ALmomof3 TPF Noob!
    Jan 5, 2013
    11
    This is a new camera & my 1st time to shoot my daughters team. Trying to improve....
  9. weepete
    weepete TPF Supporters Supporting Member
    Oct 18, 2011
    4,176
    1,289
    Glasgow, Scotland
    ETTR if possible, and don't be afraid to bump up the ISO.
    Under similar conditions I shoot with at least 1/320th, but recently I think I've been getting better results shooting at 1/640 or 1/800. Typically my ISOs will be between 3200 and 12800, but I do tend to use longer focal lengths (70-300) and my lens only goes up to f4-5.6 (yes I know I need faster glass). I also turn off all in camera processing to get the best of the burst rate. I tend to shoot in manual, AI Servo mode, shutter release - metering and af start (bbf can be awkward for long shots IME), spot metering, single AF point on manual select.
    I find it quite difficult to get the subject in focus at less than f4 on the 50mm anyway.
  10. Pallycow
    Pallycow TPF Noob!
    Nov 16, 2012
    1,697
    510
    United States
    auto
  11. Majeed Badizadegan
    Jul 14, 2011
    4,173
    2,540
    Pop up flash + 1/60 sec FTW!
  12. Pallycow
    Pallycow TPF Noob!
    Nov 16, 2012
    1,697
    510
    United States
    Absolutely.
best lens and settings for shooting gymnastics photos
canon 7d gymnastic setting
canon settings for gymnastics
canon settings for indoor gymnastics without flash
focus settings for gymnastics photography
tips for shooting indoor gymnastics on a canon
