Canon A-1... am I cursed?
Discussion in 'Beyond the Basics' started by 'Daniel', Feb 23, 2006.
  1. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    I got a Canon AE-1 for christmas. It was purchased from Jessops and seemed in good condition. After minimal use (10 exposures) It stopped wotrking. The shutter would not fire and I could not advance film. I took it back to jessops and ended up getting a Canon A-1 as replacement.
    Now after having taken 4 exposures with the camera the exact same thing has happened. I am aware it could just be chance that it has happened but I was wondering if it could be something else.
    Is it possible I'm doing something that is causing it to happen? I do not mistreat the cameras in any way.
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Just sounds like really bad luck to me! You're not using hand-loaded bulk film are you?
    Rob
  3. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    Nope, first instance, roll of XP2. Second instance, roll of Plus-X.
  4. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    You're not rolling the film round the spool the wrong way or something are you? If you open the back with the film in, can you see what's wrong.
    Rob
  5. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    Hmm, I've not tried tha, I might do it but it will mean a roll pretty much unused wasted. Oh well.
  6. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,767
    46
    Ahwatukee, AZ
    There could be a few things that can cause the jam:
    1- battery depleted (replace battery);
    2- battery terminals corroded (expensive to replace terminals if corrosion got through the body to the internal wires);
    3- dirty shutter release magnet under bottom cover (easily repaired);
    4- dirty shutter signal switch under the shutter reelease button (could try a few drops of Naphta down the shutter chute);
    5- damaged mirror damper foam (easily replaced);
    6- damaged door seals (easily replaced).
    As you can see, save for option #2, the rest are quite easy to deal with. I can tell you how to do it if interested but I'd take the A-1 back to Jessop's to have it looked at or replaced. Let me know if you want advice on the above.
    Good luck.
  7. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    Well I've tried two batteries. The numbers and letters also don't come up in the viewfinder unless I press apparently randmly the tester button and shutter release at the same time. Then if I try to expose (which it doesn't anyway) the readings go away until I do the random button press again.
    I should also say this has also happened with another camera apart from AE-1 and A-1. That was a Ricoh KR-10. Maybe I am doing something when I wind on thats causing it to jam but I don't see what.
    Thanks Mitica I think I'll take it back to jessops see if they can do something about it. If not then I will probably get my money back, assuming I can.
    I'll thwn have to find another camera that I maybe wont break!
  8. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    The Canon AE-1 was probably the most popular manual focus 35mm SLR ever sold. Most of the used ones on the market today have been used hard by more than one owner. They are notorious for the shutter squeak, which eventually leads to shutter failure. Mine died last summer. I know folks who are buying up every AE-1 they can find just for spare parts to keep theirs going, as spare parts are becoming increasingly hard to get.
  9. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    I see. So the solution is to either get a near mint/mint one or get something else?
  10. df3photo
    df3photo TPF Noob!
    Dec 31, 2004
    629
    Erie Pennsylvania
    I have had similar problems with Pentax K1000's in the past, all they needed done was opent the bottom and spin the gears around abit till they catch again, from use and probably alittle misuse the gears where missing eachother abit. but I would recomend taking it back before opening it up.
  11. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    Hope it works out. I have A-1 myself... are they really that rare?
  12. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    I doubt it they were very popular when they were released. my mum had heard of it and she knows pretty much nothing about cameras.
how to repair canon a1 shutter release
