Canon EOS 40D ignores my EV settings?
Discussion in 'Photography Beginners' Forum' started by MDesigner, Jun 18, 2008.
  1. MDesigner
    MDesigner TPF Noob!
    Jun 11, 2008
    109
    I think I must be doing something wrong here.. I have my 40D set to Av, and I hit the top button for EV adjustment..and crank it up to +2. Yet when I half-press the shutter to go back into shooting mode, the EV shows as 0. Strangely, if I go back to EV adjust mode, it still shows +2. I don't get it.. what am I missing?
  2. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    dont you have to push "set" or something after the adjustment? After that you can half-press the shutter and go back to shooting.
  3. MDesigner
    MDesigner TPF Noob!
    Jun 11, 2008
    109
    Nope. Just like any of the other settings (WB, ISO, etc), you just start shooting.
  4. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    Okay, then send it in for repair if it's not how it should be. -- What's your question if you're absolutely sure you're doing it correctly?
  5. MDesigner
    MDesigner TPF Noob!
    Jun 11, 2008
    109
    Well, I'm saying the OTHER options work that way.. maybe EV is different somehow? Was hoping some other 40D owners could chime in and verify I'm not crazy..
  6. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    I haven't played with the flash compensation but from what I'm understanding the top button "ISO-+/-" button is for flash compensation. For exposure compensation, while in any mode other than manual, press the shutter button half way then turn the big dial in the back to set exposure compensation. This will stay the same even after you turn it off.
  7. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    By 'EV' are you talking about 'Exposure Compensation'?
    On my 20D, I press the 'set' button to change the EC. One of the top buttons allows me to change the FEC (Flash Exposure Compensation)...maybe that's what you are doing?
    Double check your manual.
  8. Overread
    May 1, 2008
    24,079
    4,175
    UK - England
    sounds like something is wrong to me;
    First make sure you are in Av mode (or tv mode).
    then hold down the av+- button on the back of the camera
    whilst holding this down push the settings wheel left or right to change the value - once you reach the setting you want release the av+-button and the setting should stay put.
  9. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    There's no av+- button on the back of a 40D.
    I just played with it a lil. By "EV" I'm assuming you mean exposure compensation and not flash compensation. Just press the shutter halfway and turn the big dial in the back to adjust "EV" exposure compensation. It'll stay at that setting until you change it or go into manual mode.
  10. Overread
    May 1, 2008
    24,079
    4,175
    UK - England
    ahem - sorry I read 400 - I changed a D to a 0
  11. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    lol it's ok I often read 400 as 40D and vice versa as well
  12. MDesigner
    MDesigner TPF Noob!
    Jun 11, 2008
    109
    Wooops.. yeah. The function that shares the ISO button is for flash compensation. Duh. ;) Thanks, guys
