Canon EOS Rebel T4i Winter Question
Discussion in 'Canon Cameras' started by imtravy, Oct 10, 2012.
  1. imtravy
    imtravy TPF Noob!
    Sep 23, 2012
    33
    4
    United States
    Hey guys, so I live in Duluth Minnesota and winter is just around the corner. I would like some tips on how to make sure my new T4i stays perfect when I'm outside and it doesn't get ruined.
    Thanks
  2. MLeeK
    MLeeK TPF Noob!
    Oct 20, 2011
    6,761
    1,379
    NY
    Use a weather sleeve.
    Keep silica gel in your camera case. I keep one of those little favor pouches from weddings/showers, etc that people put candy in full in my camera bag, one in my lens bag and I think there are 2 or 3 in my rolling gear case. It all adds up to a full can that you can purchase in a craft store.
    Allow the camera to acclimate to the temperature or you will have a condensation/fogging problem.
    Do not remove the lens from the body until after the camera has warmed to room temperature and all condensation is long gone.
    I don't change lenses outside in less than perfect weather, but I use one lens for most things anyway, so I haven't really needed to.
  3. imtravy
    imtravy TPF Noob!
    Sep 23, 2012
    33
    4
    United States
    Thanks for the reply. What lens do you use the most when you shoot?
  4. MLeeK
    MLeeK TPF Noob!
    Oct 20, 2011
    6,761
    1,379
    NY
    70-200 f/2.8 OS covers about 85% of my shots. I have to switch to a wide only for full body portraits and groups, otherwise I try to use the 70-200
  5. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    Good advice above. The most important one is that you don't bring a very cold camera into a warm/humid environment without some protection. For example, if you are outside and it's well below freezing the camera & gear will get cold. If you then go into a building or warm vehicle, humidity in the air will condense on the cold gear (inside and out). So to keep your gear from getting wet, you need to protect it from the warm air until it has a chance to warm up. The best way is to use an airtight bag like a zip lock. At the very least, keep the gear zipped up in a camera bag and let it warm up gradually before you open it.
    Also, be aware that cold temps will kill the battery really fast. The best way to deal with this is to have two or three batteries and keep the spares close to your body, inside your coat. When the one in the camera dies, switch it out with a warm one. The cold one should regain it's life when it's warmed up.
canon rebel t4i cold weather
canon rebel t4i tips
canon t4i cold weather
canon t4i got wet
canon t4i operating temperature
canon t4i wet
does it hurt to take a canon eos rebel out into the cold weather
t4i cold weather
t4i weather protection
temparature weather for canon eos 550d
