Canon EOS Rebel XS
Discussion in 'Digital Discussion & Q&A' started by TurboDSM91, Nov 9, 2009.
  1. TurboDSM91
    TurboDSM91 TPF Noob!
    Oct 28, 2009
    33
    King of Prussia
    Anyone use this body? Thinking about picking one up soon (new) and would like to here some feedback. What lense(s) are good and easy to use etc.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I haven't personally used it, but it's a decent entry level DSLR camera.
    The best thing about it, is that it is compatible with all of Canon's EF and EF-S lenses. So you could put a pro quality lens on it, and it would be a fantastic pairing.
    So what lenses are good?....the expensive ones ;)
    There are some great lenses that aren't that expensive, but for the most part, price is usually a quick way to judge the quality of a lens. And aside from a few odd-balls, they are all pretty easy to use.
    So what is your budget for a lens or a couple lenses?
    The most affordable solution is just to get the 'kit' lens that usually comes packaged with this camera. I think it's the EF-S 18-55mm IS. This would be a good lens to start with. If you get more serious, you would likely upgrade to a better lens someday but maybe not. You could spend money to get a better lens right away, which is probably cheaper in the long run.
  3. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    Depends on what you plan on using it for.
    Its an entry level camera, which can be perfect for your needs.
    The more important thing when photography equipment is the quality of the lenses, as these will have a much bigger impact on your images than a different body (ie xs vs xsi vs xti,...)
    I have a friend who has one and he likes it, suites his needs just fine.
    A good lens to get off the bat is the 50mm f/1.8. Its low priced, gives great image quality, good for lower light shooting.
  4. TurboDSM91
    Oct 28, 2009
    33
    King of Prussia
    ok thanks! i dont have a lot to spend and will likely get the kit lense and maybe one other one.
  5. DennyCrane
    DennyCrane No longer a newbie, moving up!
    Sep 11, 2009
    1,375
    34
    The arctic North Coast
    The EF-S 55-255mm IS lens is a good 2nd lens for beginning. Good distance, good close-up, etc.
  6. altitude604
    altitude604 TPF Noob!
    Oct 2, 2009
    720
    5
    Happy Valley-Goose Bay, NFLD, Canada
    ^ seconded.
    I've got the XSi with the Kit 18-55 and 55-250 IS.
  7. TurboDSM91
    Oct 28, 2009
    33
    King of Prussia
    awesome! then thats what ill look for! how much am i looking at for the 55-250 lense?
    also newb question what do the numbers mean (55-250)?
  8. altitude604
    Oct 2, 2009
    720
    5
  9. DennyCrane
    Sep 11, 2009
    1,375
    34
    And that's a good price... it's $45 cheaper than most retail places.
