Canon F-1 Light meter problem
Discussion in 'Film Discussion and Q & A' started by tom beard, Jul 3, 2009.
  1. tom beard
    tom beard TPF Noob!
    Mar 2, 2009
    175
    5
    So. Cal mountains east of LA
    Hello All,
    I recently unpacked my F-1 which I've had carefully stored for over ten years, and got a new battery for it (same as the old one). I turned the light meter switch to on, set the asa to 100 and the shutter speed to 2000 as instructed. Looking through the viewfinder (the meter scale on the right), should have lined up with the blue mark near the bottom. It was above the marker. When I readjusted the meter from battery test to TTL metering, I had to stop down the lens a bit more than a full stop to approximate the battery test readings. When I shoot a test roll, should I use the re-adjusted setting as a guide or ignore the battery test reading? Since the camera has been sitting for so long unused should I take off the viewing prism, take out the split image focusing screen and remove the lens and clean everything I can get to or has it just gotten old and creaky from non use?
    Thanks, Tom Beard
    Canon F-1, 28 &50 mm fixed focus, 70-200 Soligar zoom
  2. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,991
    495
    L.A.
    Canon made two cameras they called "F-1" -- the first in the 1970s and the
    other in the 1980s. They are different cameras.
    Is yours the original F-1 that uses a 1.3v PX625 mercury button battery or
    the "New F-1" that uses a 6v PX28 battery?
  3. DeadEye
    DeadEye TPF Supporters Supporting Member
    May 16, 2007
    960
    11
    As I recall the new replacement ( Cross referance ) battery is non mercury as per the new EPA approved battery. Its higher in voltage and moves the meter by a stop. There is a little disk shaped diode that fits under the battery that will correct the meter reading.
    If you can't find one lemme know as I have one.
  4. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,147
    927
    Woodbridge, Ontario, Canada
    Sounds like original F-1.
    I do not recall a light meter switch on my nF-1 ... nor a blue area under the match needle.
  5. dxqcanada
    Dec 4, 2008
    6,147
    927
    Hmm, based on the User Guide ... the battery check should have the needle above the blue zone.
canon f-1 problem
canon f-1 problems
canon f1 forums
canon f1 light meter
canon f1 light meter contacts
canon f1 light meter doesnt work
canon f1 matchneedle not working
canon f1 meter
