Canon F-1 meter repair
Discussion in 'Film Discussion and Q & A' started by jwkwd, Nov 7, 2007.
  1. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    Greetings, I have a Canon F-1 ( early, long throw ) and the meter stopped working. It did work since I have had it, but it was sitting for awhile, now it does not. I put a new battery in it, no luck. I gave it a good smack, no luck. There is no obvious corrosion in the battery compartment. I did check both batteries and the voltages were correct. 1.35 volts - and they are wein Mercury free. What I was wondering is, for a Nikon F2, I would send it to Sover Wong. Does anyone know of a Canon equivalent to Sover? Or, any ideas of what I could check? The meter does have movement when you move the camera controls, but does not show battery condition when at ASA 100 and 1/2000 so it is not frozen. I know that I could get another one for cheap, but like I said, I have had it a while and I tend to hang on to things. It certainly works without the meter, but it is kind of handy to have. TIA
  2. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Looks like you might be stuck with the Sunny 16 rule.
  3. selmerdave
    selmerdave TPF Noob!
    Nov 30, 2004
    454
    Brooklyn, NY
    Or even better and more useful a hand-held. I think you're money would be better spent there, just my opinion of course.
    Dave
  4. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    Thanks guys! I have no problem with sunny 16 and I do have a hand held, which looks like I will be using more ;). It might be an earlier retirement for the F-1. It is just one of those cameras that I have had a long time, and have gotten used to having it in the car all the time. I am primarily a Nikon user, so I have quarrels about being brand specific. I guess it's time to put batteries back my F2 and continue giving that a workout.
  5. selmerdave
    Nov 30, 2004
    454
    Brooklyn, NY
    I'm surprised that you have a hand-held and yet still use an in-camera meter? Any particular reason?
    Dave
  6. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Dave has a point. I don't usually trust any meters in any of my cameras. I usually abide by the Sunny 16 rule, or certain exposures I've found that work in certain situations due to trial and error.
  7. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    And certainly a very good point. I have had good luck with the meters built into the cameras. Like I mentioned, the F-1 was usually always in the car. The meter I have ( Sekonic L-398 ) is in another bag with another system. I know it probably sounds strange, but I have a couple bags with different systems, for what I might decide to do. e.g. If I were using a backpack, I have an F4s w/35-70 and 70-300 if I was going to walk and shoot wildlife. I like the AF and the matrix metering or the option of using spot. I have a over the shoulder bag with a F3 w/MD-4, 55 macro, 300 and 35-135. I seem grab that one since I tend to shoot slide film with it and I know that one is going to work no matter what. Again I am comfortable with the metering in it. I will switch bodies or lenses for which ever bag might be more comfortable at the time. I do use the hand held on the occasions that something just does not seem right as somewhat of a reference, then often split the difference. So for one particular reason.....hmm, like I said I have had good luck with the camera meters, or perhaps the laziness factor comes in.
canon f-1 repair
canon f1 forums
canon f1 meter repair
canon f1 repair
