Canon Flashes
Discussion in 'Photography Equipment & Products' started by TheLogan, Mar 24, 2009.
  1. TheLogan
    TheLogan TPF Noob!
    Dec 20, 2008
    140
    I was wondering what the differences are between the speedlight 430 and the speedlight 580. What makes the 580 almost double in cost? and is it worth the extra $? I'm looking to buy a flash that will perform better than the built-in flash.
    Thanks!
    Logan
  2. JustAnEngineer
    JustAnEngineer TPF Noob!
    Apr 11, 2008
    609
    Heart of Dixie
    Mainly, the 580EX II (guide #190) is more powerful (brighter) than the 430EX II (guide #141).
    The 580EX II is able to act as a master to trigger a second flash.
    Any flash that you can tilt to bounce off of the ceiling (or a wall) will be a tremendous improvement over direct flash.
  3. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    The 580 is brighter, can act as a mater or slave, has a built in bounce card and several other things. It's physically bigger than the 430 too. The 580 is dust/weather sealed and it cycles (recharges) faster. The 580 also has a PC sync port whereas the 430 doesn't. The 580 can also be powered from an external power source. The head on the 580 can more more as well.
    The 430 is a good flash if you're not planning on controlling other remote flashes with it. If you want to do this eventually, it's an easy upgrade to buy a 580 for your next flash then the 430 will become the slave.
  4. TheLogan
    TheLogan TPF Noob!
    Dec 20, 2008
    140
    So if I were to buy the 430, would I be seeing poorer quality Images than if I bought the 580? In other words, is the 430 capable and worth the money?
  5. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    I have two of them and they are quite capable flashes. It really depends on what you plan on doing with it. The 580 has the advantage for things like using it with a softbox where the extra power comes in handy. Generally speaking, my 430's can do everything I need them to do. I often carry a 430 with me in my smaller bag when I'm traveling light as it takes up much less space. I bring the 580 along when I need a master or I plan on shooting lots of shots fast.
  6. TheLogan
    TheLogan TPF Noob!
    Dec 20, 2008
    140
    well, I want to start shooting some weddings (not for money, but just for the experience) which is typically done with a softbox on the flash, is it not? so would the 430 be adequate for that?
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Shooting with a softbox on your flash, isn't the easiest way to work...to be big enough to make a real difference, it would have to be fairly large, which would be hard to handle during a wedding. Typically, you will want to bounce when you can.
    I have a 430EX and it's a great unit. The 580EX is better, for the reasons/extra features listed above...but the 430 is certainly capable of getting the job done.
  8. Overread
    May 1, 2008
    24,062
    4,171
    UK - England
    he could be refering to something like the lumiquest softbox - far smaller than the studio sotboxes and usable when out and about. Certainly something like that is good for when you can't bounce.
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I assume that's what he was talking about...but I still think that they aren't a great solution. The smaller ones are too small to be worth using, and the larger ones are just too cumbersome to be running around with (IMO of course).
    The flash accessories that I like, act as a bounce card but can easily be adapted to full deflection when needed. For example, the Demb Flip-it and the Lite Scoop.
  10. Overread
    May 1, 2008
    24,062
    4,171
    UK - England
    hmm I have not used the mini-softbox though I have considered it for a small flash unit and macro work -- but the larger box (or rather medium sized one as they have have alarger version) appears to work well to my eyes - though I will admit that I do little people work.
    For getting around the place it does not get in the way I find - and I am wandering round zoos and woods - sure it gets caught once or twice but unless your getting really close to things for macro shots it does not much get in the way I find
  11. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Don't those softboxes block the AF assist beam?
  12. Overread
    May 1, 2008
    24,062
    4,171
    UK - England
    Nope = from their range : LumiQuest® Photographic Accessories | Product Guide
    only the newer softbox III blocks the AF assist beam and that looks to be a much larger box and more suited to a stand than on camera.
    The Softbox (my one) and the Softbox mini don't block the AF assist light and the Softbox II is only for select flashes (bare bulb)
