Canon Raw Files
Discussion in 'Beyond the Basics' started by 'Daniel', Sep 23, 2005.
  1. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    I'm finding editing these somewhat confusing. I d/led Adobe DNG convertor 3.1 which supports .CR2 files but you need CS2 to use the files it creates I think. I have CS and the next convertor down 2.4 doesnt seem to work with CR2 files.
    Can anyone help?
    edit - i'm using a 350D (Digitial Rebel XT)
  2. SLOShooter
    SLOShooter TPF Noob!
    Dec 21, 2004
    421
    I would imagine that a plugin that works for cs2 would also work for cs, but I could be wrong. Did you stick it in the plug-ins\extensions folder?
    Just throw it in there and try editing one of your RAW files and you'll find out whether it works or not quick enough.
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Do you have the latest version of 'Adobe Camera RAW'? It's a free download.
    Not every .CR2 file is the same. You need a newer PS plug-in to read 350D files than you do to read 300D files...for example.
  4. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    No the problem is that I d/led the latest Adobe Raw but that only works with CS2. It says so on th website. And you can use the latest DNG Convertor without CS2 but I can't open DNG in CS, do I need a plug-in for that too?
    Maybe thats the problem, i'll report back.
  5. SLOShooter
    Dec 21, 2004
    421
    On Adobe's site it says that only v3.1 of the converter has file support for the 350D. v3.1 only works in CS2 so to use that plugin then yes, you would need to have CS2.
    However I'm sure that the software included with the camera must have a plugin that works with PhotoShop, be it CS or CS2.
  6. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    You'd think that wouldn't you. There isn't that I can see. You can view them in the Canon software and then process them to tiff jpg or bitmap but I may as well have shot them originally in jpg.
  7. SLOShooter
    Dec 21, 2004
    421
    I just did some searching around on the internatron and it appears that there is no support for the 350D in Photoshop CS. Your stuck either upgrading to CS2 and using v3.1 of Adobe's RAW converter, or using the one provided by Canon. I'm sure there are other thrid party software's out there that can handle RAW conversion as well if you don't like the one provided by Canon.
  8. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,068
    89
    Kankakee, IL
    Ya know, I've been thinking the same way. I'm an old school, "get it on the neg" kind of guy. So I'm wondering... if I make the exposure properly, what do I gain by shooting raw? More work?
    -Pete
  9. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    I have the CRAW working with CS... But I can hardly remember how I installed it.
    I did have to manually copy the plug-in somewhere into the photoshop directlory.
    Hope this helps any.
  10. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    5
    Pasco, WA
    -Expanded dynamic range (ability to pull details from shadows & highlights)
    -Post shot control/adjustment of white balance
    -The ability to drastically alter the mood of the shot without affecting the quality of the image (lighter/darker/color cast etc.)
    -Better control over contrast, saturation, and sharpness of the pics
    So, you can do all the above in jpegs (maybe), but it'll actually be more work than doing the same thing with a RAW file. Once you have one shot of a series dialed in you can batch process RAW files with the same parameters.
    But, [large if here] if jpegs are doing what you need your pics to do for you & that floats your boat then you'd gain nothing by shooting RAW. But, [another large if] if you haven't ever shot RAW you really don't know, do you? ;)
  11. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    :x I did that. But it didn't seem to work. I'll try some stuff again see if I can get it happening. Maybe if I can find a dng plug-in for CS.
  12. Christie Photo
    Jan 7, 2005
    7,068
    89
    Kankakee, IL
    This is very helpful. I've not received this detailed answer before.
    But... help me a bit more please. I want to understand all this. If I've lit the photo properly (both exposure and color temp), would I still benefit from shooting raw. I have (and do occasionally) shoot raw, but it seems all I end up doing is converting to tiff. How can sharpness be controled?
    Thanks!
    -Pete
