Canon Telephoto Lens Help
wmc1117
Ok, so I have been playing around with my 18-55mm lens for awhile that my Canon XS came with but I feel really limited with the zooming only getting to 55. I am going to be taking a nature photography class so I am looking into getting a tripod and I want a telephoto lens possibly reaching 200 to 300 zoom I was curious if anyone has some suggestions on the best I can get for under 300? I also plan on picking up the nifty fifty for street shots? Any ideas would be greatly appreciated.
The Canon 70-300 is decent. I shot with it for some time before replacing it with L glass (which, by the way was worth every penny). It comes in at just over $500.
0345B002 Canon EF 70-300mm f/4-5.6 IS USM Autofocus Telephoto Zoom Lens - USA
To drop lower than that, you'll probably have to look at non-Canon lenses. Tamron makes one under $200:
AF017C700 Tamron 70-300mm f/4-5.6 Di LD 1:2 Auto Focus Macro Zoom Lens with Hood for Canon EOS, 6 Year USA Warranty
and Sigma has one just over $200:
508101 Sigma 70-300mm f/4-5.6 APO DG Macro Tele Zoom Lens for Canon EOS Cameras
I can't vouch for the quality of the Tamron or Sigma lenses. I personally would be suspicious with that wide a focal range and that small a price tag. But, then again if it's for a class it may be just right for you.
Your option under $300 are rather limited. There are several options, most of which are very similar. 70-300 or 100-300mm lenses from Canon, Sigma or Tamron.
THIS ONE is pretty good, for the price. It should be OK, especially if you are going to use with with a tripod.
The 70-300 IS, is a good option. Much better than the other 70-300 lenses...but as mentioned, it's expensive. The one I linked to, doesn't have IS and is less than $200.
Between the Tamron and the Sigma, that Canon 75-300 is still probably the best. I didn't even think of that one.
Thanks for the options, I'll look into those, also what is the price for a lens a step up in quality from that specified 75-300 lens?? Also if you guys could recommend a wide angle lens for Canon that I can look into maybe 20-35mm? Or a wide-angle prime?
For the OP some food for thought. Instead of getting something now for under $300, you might consider waiting a bit, saving your money and look at the 70-200 f4L. Top quality glass that will last you many, many years.
Canon | 70-200mm f/4.0L USM Autofocus Lens | 2578A002 | B&H
The image quality of this lens is hard to beat and would be a lens to build on in the future.
The only reason to upgrade from this lens in the future would be for the 2.8L version for low light.
That lens mentioned above, the 70-200 F4 L, is a top quality lens and actually a pretty good deal at it's price. It's the least expensive of the Canon 70-200mm lenses, of which there are four;
70-200 F4 L
70-200 F4 L IS
70-200 F2.8 L
70-200 F2.8 L IS
As for a wide angle, are you looking for something to replace your 18-55mm lens, or are you looking for something wider?
To replace that lens, the Sigma 18-50mm F2.8 or the Tamron 17-50mm F2.8 are both great options for a good price. A better option at a much higher price is the Canon EF-S 17-55mm F2.8 IS. There is also the Canon 17-40mm F4 L and the 16-35mm F2.8 L.
If you want a wider lens, look at the Canon EF-S 10-22mm or the Sigma 10-20mm.
I have the Canon 70-300mm f/4-5.6 IS USM. It's a decent lens but if you can wait and save a bit longer for one of the suggested 70-200mm L lenses you will be ahead in the long run.
A Canon 55-250 is STM f: 4-5.6 might suit your needs well.
I don't think the OP will still be waiting 6 years after the class.
