Canon Wide or Ultra Wide angle Lenses? Zoom or no.... Help
Discussion in 'Digital Discussion & Q&A' started by Hfry, Jul 3, 2007.
  1. Hfry
    Hfry TPF Noob!
    Aug 19, 2006
    195
    dssd
  2. PhotoPhoenix
    PhotoPhoenix TPF Noob!
    Jun 24, 2007
    126
    New York City, NY
    i use a 17-85ef-s for wide angle and it holds up pretty good. anything you want for wide angle will obviously have to be an ef-s lens.
    :edit: i shoot with a 30D also.
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    28mm isn't very wide on that camera...there are basically two steps wider for you. The first step would be to the 'normal' range on these digital bodies...this starts at 17 or 18mm. The cheapest lens is the 'kit' lens that usually comes with the camera...EF-S 18-55mm F3.5-5.6. The best choice is the EF 16-35mm F2.8 L or the EF-S 17-55mm F2.8 IS. There are plenty of lenses in between...the Tamron 17-50 F2.8, for example.
    The next step wider is really wide. The Canon EF-S 10-22mm F3.5-4.5 is the best choice here.
  4. PhotoPhoenix
    Jun 24, 2007
    126
    New York City, NY
    he is using the 30D though, the 30D has a multiplication factor which is why i said using efs when talking about wide angle is almost necessary.
  5. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Not necessarily.
    The 17-40mm F4 L and the 16-35mm F2.8 L are not EF-S lenses but would be good wide lenses for the 30D. They are more expensive than comparable EF-S lenses though...although the EF-S 17-50 F2.8 IS, is quite expensive. The widest lens, the 10-22mm is an EF-S lens though.
  6. Hfry
    Hfry TPF Noob!
    Aug 19, 2006
    195
    Yeah the efs 17-50 IS IS is a nice piece of glass
  7. Hfry
    Hfry TPF Noob!
    Aug 19, 2006
    195
    thank you Guys. Helpfull
  8. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    there's also Nikon and Sigma ULTRA wide lenses available that are not EF-S. However I agree with the above.
    17-55 f2.8 IS or Tamron 17-50 (if you want that range) or the EF-S 10-22 f3.5-4.5 are the ones to look at.
