Canon40D indoor basketball shots
Discussion in 'Photography Beginners' Forum' started by mjterry, Jan 29, 2008.
  1. mjterry
    mjterry TPF Noob!
    Jan 29, 2008
    I bought a new Canon40d and all my photos are blurry. Disappointing. What settings should I be using?
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    dude. You should really elaborate. First I think you should have understood SOMETHING about photography before buying a 40D...but besides that...
    Your shutter speed is just too slow. Basketball games are dark.
    Open up your aperture, get a faster lens, maybe bump your ISO up a few stops...
    What lens are you using?
  3. ashadiow
    ashadiow TPF Noob!
    Jan 16, 2008
    96
    Duluth, MN
    #1, you are probably shooting at around ISO400. At your average kids indoor basketball game the lighting is BRUTAL. You will probably ned to be shooting at around ISO800-ISO1600.
    #2. When you zoom out with the kit lens you have (while very nice) you are at F5.6. That just isn't a lot og light getting to the sensor which means you will ahve to shoot longer exposure causing the blurry exposures you are explaining. Consider the Canon 70-200 F2.8 IS for this kind of work. Or even the Sigma 70-200 2.8. Then shoot at ISO 800 and I bet your exposures will be around 1/250th which under most cases should be quick enough to stop the action.
  4. yeti
    yeti TPF Noob!
    Jan 8, 2008
    115
    Just throwing my two cents there:
    1) The 40D has a two-step shutter button. Make sure you are focused and focused on the correct place before you press the button all the way. Normally the 40D will focus on the closest object it finds in its focusing spots, so beware: if you are shooting through glass or something, it might focus on a smudge on the glass, or the wrong player.
    2) If you are using the kit lens, you HAVE TO turn image-stabilization off for action shots, or it will introduce unwanted movement into your shot.
    3) Try not moving your camera too much during shots. It's just a camera like any other - if you move it, it will blur shots.
    4) If you try to pan a moving object, make sure you are doing it right (I know I am not, that kind of thing takes practise and lots of ruined shots).
    5) Use a telephoto lens with 2.8 apperture. Your kit lens is way too slow for this kind of work. The lens suggested above is great. It's an expensive monster, but it's an expensive monster that will do the job for you. Make sure you turn off horizontal IS for panning.
    6) If you like put your camera in manual mode and set it so that your depth of field is the entire court, or that part of it that you are interested in. This way you don't have to waste time and worry about focusing. You can also combine that with panning and get a really nice blurring effect.
    Something else? You really aren't giving too much detail.
