Can't focus with extension rings on Canon
Discussion in 'Photography Equipment & Products' started by Aquarium Dreams, Mar 8, 2007.
  1. Aquarium Dreams
    Aquarium Dreams TPF Noob!
    Jan 14, 2007
    731
    I have some Kenko extension rings and when I attach them to my camera (400D) and lens, the camera won't focus. I've tried manual and auto focus and various combinations of rings with different lenses, all to no avail. I'm thinking about returning them, but others seem to have great results with these. Am I doing something wrong?
  2. TomHuck-wa
    TomHuck-wa TPF Noob!
    Jan 20, 2007
    81
    South central Washington state
    I have Kenko rings, and a 20D, they work fine. You will have a very narrow fov, mine is out there a ways with the 200 lens. Put the rings and lens on, find a contrasting spot, (I used a doorknob on a white door) look thru the viewfinder and move back and forth from 1 foot to 6 feet or so very slowly, depress the shutter button half way every foot or so, till you see if it starts to bring the subject into focus. Hope this works for you.
  3. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    I agree with that. Your depth of field will be extremely narrow...and I believe that extension tubes also prevent your lens for focusing at infinity. With the tube on, start with the lens very close to something and slowly move back until you find where your working distance will be.
  4. Aquarium Dreams
    Jan 14, 2007
    731
    Thanks, and WOW, you two weren't kinding about the narrow focus. The wider the lens, the closer I have to be to focus with an extension ring. I added the 12mm ring to my 28mm lens on the 400d and there might have been space to slide a couple playing cards between the front element and the surface in focus. Every combination of lens and rings focused really close. 300mm with all three rings focused at about four feet and my cat's eye filled a quarter of the frame. Is this normal? I suppose I was expecting more of a telephoto effect versus the macro effect I'm getting. These could be fun, but they're not exactly what I thought they would be.
  5. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Extension Tubes are for macro type work. They allow you to focus with the lense closer to the subject than without.
    If you were wanting more zoom than you would need a tele-converter to magnify your zoom lense.
    Cheers
  6. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    :thumbup:
  7. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Extension tubes are for macro photography. They take away your infinity focus and allow you to focus closer. Using all 3 kenko tubes (65mm) on a 50mm, gives you better than 1:1 reproduction.
  8. Aquarium Dreams
    Jan 14, 2007
    731
    :lmao: Well, now I wish I had done more research before buying. In my defense, I read an article that suggested buying these with my 24mm TS lens to "get more miles out the lens," or something to that effect, and I assumed by miles the writer meant millimeters. That's what I get for assuming instead of asking.
    That might just make these babies worth keeping.
    Thanks everyone.:)
can't focus with canon extension tube
can't get extension tubes for lens to focus
cannot focus extension tubes with 50mm lens
cannot focus using macro tube
cant focus using extension ring
extension tube can't focus
extension tubes canon unable to focus
extension tubes cant focus
i cannot focus with extension tubes on my 28mm
my camera can't focus with extension tube
